JcrOffroad - prototyping begins!
Status
Not open for further replies.
Bird Dog Off Road
Jody
Phoenix, AZ
www.youtube.com
Draughon
Daylon
Dallas
BMW 4-Series
Vanguard rear with only one carrier installed. You can remove the carriers after your trip if you don’t want to deal with hauling all the gear around.
I like it! I'm sure there's an option for a longer swing arm so it centered?
Redhalo7
Wade
Chicago
'24 Bronco
Does the prerunner I already purchased fit on the Vanguard bumper? Looks like it has different mounting.
Rick Astley
Up Doug's ass
d
Very excited to see where the rear bumper ends up price wise and if it's comparable to the Jeep offerings from @JcrOffroad then this is very doable!
Couple of final product questions:
  • Will there be a synchronizing heim joint for Bronco application like there is for Wrangler (images 1 & 2 below of your Jeep product)?
  • Are you using the plate below the spindle as a washer? It doesn't appear to rotate with the arm, hence having the locking location for the pin.
    • Reason being I would probably want to trim down some of the plate so it doesn't protrude past the bumper in places.
Ford Bronco JcrOffroad - prototyping begins! 1642112581779
Ford Bronco JcrOffroad - prototyping begins! 1642112606025
Ford Bronco JcrOffroad - prototyping begins! 1642112739104
FireBall
Gene
Winston-Salem, NC
F350, Venza, Catalina 22
I figured the protrusion beyond the bumper was to allow a locked-open position?
JcrOffroad
JcrOffroad
Portage, Mi
2021 Ford Bronco Badlands
That is for the spring loaded plungers that hold the carriers open.
We also have no plans to make other carrier options.
Primed_in
New Mexico
Ford Edge
Here is First attempt on the front camera relocation. It’s going to need to be taller, but the concept worked.
I’m probably just dumb, but is this live on your site or does it come with the bumper?
Rick Astley
Up Doug's ass
d
Would you have a problem with striker plate for the plunger being trimmed back?
Is the heim joint a "different carrier option"? (apologies, I don't know your entire product line by variation/name, I simply see your Jeep carriers having a heim joint to synchronize opening and the Bronco latching at the bumper)
JcrOffroad
JcrOffroad
Portage, Mi
It’s not live yet. Still sorting out the final prototype.
JcrOffroad
JcrOffroad
Portage, Mi
The carriers won’t latch if you trim the tracks.
We do not have a hiem carrier setup for the bronco.
JcrOffroad
JcrOffroad
Portage, Mi
Your front and rear bumpers look awesome and I have one quick question. I ordered the Capable bumper to get the fog lights and wondering if your bumper is a direct bolt on with the Capable option. I saw a video on the base plastic where the tow points had to be cut off in order to install an after market bumper. Also, will these workd with ACC?
Uh. That probably had something to do with the intercooler mounts? We don’t cut anything.
LUX package is the only model with ACC. It requires relocation
JMV123
Wyoming
2017 Ford F350/2015 Subaru
Thank you and that is exactly what I was looking for in a front bumper. Winch, bull bars that look pretty stout, 3” lighting ports, high lift jack mounts and the ability to use the ACC with a work around.
Status
