Jb4 problems, anyone else?
pony2bronco
Ryan
Maryland
2DR FE
Installed everything according to the pictures / lethal videos. Now I have check engine, service soon, low idle/power loss, pre-collision assist not available.
Codes: PC60B, PC66D
Tried updating to latest firmware and same result.
Ducati1098
Codes: PC60B, PC66D
Double check those code numbers. They aren’t correct.
pony2bronco
pony2bronco
Ryan
Maryland
2DR FE
Email or call jb. Excellent support.
I've been trying. They don't have phone, no email response luck yet. They did have a rep on their internal forums reply, but it made no sense. Said that my version doesnt use the TMAP plug and go back to factory and then email for new firmware. No reply to emails requesting, and Lethal confirmed that the 2.7 definitely uses the TMAP plug.
0ne
Nate
CO
Flex
Oh man these Broncos don’t like having their brains messed with
Ground_zero298
Scs michigan
This is the email you used?
[email protected]
On mine I used both plugs.
pony2bronco
pony2bronco
Ryan
Maryland
2DR FE
Solved, kinda. They had a batch of JB4 for Bronco sent with the wrong chips inside. Hopefully can get a new one soon.
No_Craw
Noah
South Carolina
22 Bronco, 89 Bronco II
Literally just installed mine today. Same problem. Guess I’ll have to call also. Keep me updated on yours
Ground_zero298
Scs michigan
I had a self inflicted issue on mine I was expecting to pay for. They took care of it. Shipping and support was really good to. They will get you taken care of.
PghBronco
Pittsburgh
Nah its just the JB4. another member had an issue with their CS and support as well.
pony2bronco
pony2bronco
Ryan
Maryland
2DR FE
Replacement chip was a pain to bend and install right, but it worked! Still having some issues though getting it to read the obd2/display gouges, wondering if I need to replace that next.
On the bright side - I thought I was gonna have to go into Forscan to clear the check engine light (was still on even after removing the JB4 and driving stock), but somehow without doing anything the JB4 cleared it with the correct chip in.
Ducati1098
I’ve never been able to get the gauges to work either for some reason 🤷‍♂️
