- Joined
- Aug 20, 2020
- Threads
- 16
- Messages
- 93
- Reaction score
- 256
- Location
- Newfoundland
- Vehicle(s)
- 2011 Honda CRV (I just like Broncos Ok?)
- Your Bronco Model
- Undecided
Sorry if already asked, but how big is it?
Build and Price wasn't very clear on that at all which is where the confusion was. B&P has it at $695 for both the MT and Beadlock. Oh well.
No no no no. The B&P is accurate.From the rockstars on B&P:
This is for the Badlands build.
amb is growing on meHey I was there at the same time! I would have said hi had I known you were a 6Ger. Here are the few pics I took from today and Saturdays event at Ted Britt:
But at the price that you get the factory lift as well as the factory 35 star under warranty that will not create a problem with any type of gathering it’s one less thing you have to worry about the manufacturer declining any issues you have. The competitor jeep well tonight anything if you make practically any modifications so why not spend a little more that actually will be Under factory warrantyAdding 35"s to a Badlands looks like a no sweat affair. Lots of room left in the wheel well....
Why is that BL missing the sway bar disconnect button???? Damn these preproduction
It's actually only missing the turn assist button. That feature is not available with the manual transmission.![]()
That BL is a manual transmission. So that missing button is the Trail Turn Assist, which is only available with the automaticWhy is that BL missing the sway bar disconnect button???? Damn these preproduction units...
It looked to have it to me - only one slot should be empty right?Why is that BL missing the sway bar disconnect button???? Damn these preproduction units...
The stick would have the 2.3I didn't drive it. They wouldn't even start it so I could hear the 2.7 purrr.
When are they coming to Pennsylvania?Thanks for the photos. Can’t wait to see them here in PA. I went through the same thought process between BL and BD and came to the same conclusion - ended up choosing BL with the high package and 33’s. Hope I’m right!
The A51 overland Bronco is a stock suspension Badlands on 35s.Adding 35"s to a Badlands looks like a no sweat affair. Lots of room left in the wheel well....
Late April...there was a post so somewhere on this forum that had links to register at local dealersWhen are they coming to Pennsylvania?
The BD (AMB) was a 2.7The stick would have the 2.3
Yes but he asked about pumping the clutch and rowing through the gears.The BD (AMB) was a 2.7
That's what she saidSorry if already asked, but how big is it?
