It was glorious!!! 2 points to note though.
TheWoo
Manhattan, KS
2021 Gladiator Mojave
Why is that BL missing the sway bar disconnect button???? Damn these preproduction units...
It has the SB disconnect, but doesn't have the trail turn assist because it's a manual.
mtap
Mervin
Cape Coral, FL
Toyota Tundra, Hummer H3, Harley Sportster
My apologies...never looked at the BL. Thought it was standard on it...was using BD as point of reference.
From the rockstars on B&P:
This is for the Badlands build.
Mike5681
Ohio
More Door Sasquatch
disco is still there just the buttons shift to the right to make up for missing trail turn assist because this is a manual transmission.
adamruiz2001
SoCal
Ford SVT Lightning
OHHHHHHH, that makes sense, thanks man for clarifying that for me!
stras27
stras27
Matt
Ford Fusion Hybrid
Thanks for the pics. Do you push in the clutch and row the gears? How did it feel?
I didn't drive it. They wouldn't even start it so I could hear the 2.7 purrr.
Tricky Dick
Dick
PNW
www.TD-Distributing.com
OK I figured you would have still fiddled with it turned off.
Ranger6G
Ranger
OBX North Carolina
Ranger
Looks like less crowd than Ted Britt Fairfax on Saturday. What did you get?
tyrobronco
CC
Central Florida
2021 Bronco,2017 Ford Fusion Energi
Glad you had a good time. I'm looking to getting to sit in one. I've seen it live but no touching.
The 12" screen dominates the dashboard in all the photos I see. I look forward to seeing it in person just to see if it takes up as much space as I suspect.
fraserjr
Fairfax, VA
2021 Ford Bronco Badlands 4 Door
I was at both events and definitely less people than the Fairfax one. It was also rainy, cooler and mid-week so probably less than expected turnout.
fraserjr
Fairfax, VA
Dealer event a Ted Bitt Ford in Chantilly VA.
I loved every bit of it. For a long time (or what felt like a long time) I went back and forth between a Black Diamond with Squatch/Mid and Badlands with 33s/High (due to budget mostly). They had both there and my decision to go with the BL was confirmed. The 12" screen (with 360) IMO is greater the Squatch if you have to choose. Reasons being utility and height. I don't need 35" tires on the East Coast and without a step it was a strong step up to get into (wife and kids would struggle more). The 33s still felt huge and the 12" screen looked beautiful. The soft top looks like a pain in the ass though.
2 items of note/debate. You will notice that the 33" came with the upgraded beadlock rims but had the AT KO2s on them. I asked the event guy and he said that the KO2s were the tire that came with both and you were only upgrading to get the beadlock. This goes against what is published and is still preproduction but thought it was interesting and may cause a firestorm.
Next, the BL had a cargo mat in the trunk. The guy said it was an option but I can't remember seeing it. Either way, the cargo mat blocks the tie down straps so if you want to store the doors it is not going to be easy to reach those hooks under the mat. The trunk was still durable even without the mat so you may want to consider that if you opted for that upgrade. IMO it would be one or the other and the mat isn't worth it unless you have like dog crates or are using it to move bricks.
Overall, incredible vehicle and I am really excited to get it.
Hey I was there at the same time! I would have said hi had I known you were a 6Ger. Here are the few pics I took from today and Saturdays event at Ted Britt:
Ford Bronco It was glorious!!! 2 points to note though. IMG_4861
Ford Bronco It was glorious!!! 2 points to note though. IMG_4859
Ford Bronco It was glorious!!! 2 points to note though. IMG_4858
Ford Bronco It was glorious!!! 2 points to note though. IMG_4851
Ford Bronco It was glorious!!! 2 points to note though. IMG_4850
Ford Bronco It was glorious!!! 2 points to note though. IMG_4843
Ford Bronco It was glorious!!! 2 points to note though. IMG_4839
Ford Bronco It was glorious!!! 2 points to note though. IMG_4835
Ford Bronco It was glorious!!! 2 points to note though. IMG_4826
Ford Bronco It was glorious!!! 2 points to note though. IMG_4813
Mayflower2010
Newtown, PA
2021 Bronco, 2020 Explorer
Thanks for the photos. Can’t wait to see them here in PA. I went through the same thought process between BL and BD and came to the same conclusion - ended up choosing BL with the high package and 33’s. Hope I’m right!
BigFootie
Wisconsin
That AMB black diamond looks pretty sweet. Thanks for posting.
