It’s Prime Day - Amazon
Tricky Dick
Dick
PNW
www.TD-Distributing.com
The only negative I have to say, is that the temperature readings are pretty much always wrong. I don't know where their sensors are inside, but I just bought a two pack of fridge temperature gauges and put one in each compartment. Then I learned the correlation between the physical thermometers and the BougeRV display panel.
I think it's in the bottom right, I set some hot food on the bottom and the temp skyrocketed, even though the internal temp was still very cold.
PlannedSickDays
Rick
West Des Moines
2021 Big Ben SAS
Thanks! Found a pretty cheap Bimini mesh top this way. Worth a try for $40!
Mine arrived and installed today in about 20 mins. I haven't gave it a full road test outside of a quick trip around the block. For now, pretty happy with it and the price. If it ends up falling apart, I'm not out much.
andysaurus_rex
Andrew
VA
Ford Bronco
Such bad timing, I should have my Bronco within the next 2 weeks, but I don't know what I need yet
You can
yeah mind me arrived today too. Going to install it tonight.
