Is the Ford Performance tune worth it?
Brnzbronc
Indianapolis
I highly recommend it.. especially if you plan to swap out the front diff.. also I believe you can swap the front steering rack with the programmer as well. I didn’t write down all the parts numbers listed from the program that allows you to swap out at one of the prompts.. maybe the guys at Lethal would know
Dtrain72
Kinnelon NJ
2022 Bronco Badlands / Sasquatch
I just added the Roush cold air intake, a Ford Performance cat back exhaust, and the performance tune (on the 2.3) all in one go. The truck sounds amazing. The exhaust gave it a nice snarley tune, and on cold starts it sounds shockingly good for a 4 cyl. Ford perf did a nice job (or whoever makes it for them - I'm not sure). On the tune, I noticed a difference for sure, but I need a less traffic-ey day to try a brake-hold 0-60 starts 40-80 type acceleration on the highway. I have to say though, even the stock 2.3 impresses me. I'm coming out of a 2017 Raptor that I drove hard. The 2.3 never disappointed me from day 1. Super responsive and a surprising amount of power. Would love a bit more 0-60, and that's why I got the tune.
85crawlrunner
Josh
Southern Utah
21’ Wildtrak
Does anyone know how to find out if one of the tunes was already done on a vehicle?
I purchased mine used and had 37’s pit on it before taking possession. I was actually very pleasantly surprised at how well it performs already after reading so much about putting a tune on it.
Dtrain72
Kinnelon NJ
That's a great question - look forward to seeing if anyone knows. I picked mine up from the dealer assuming they did it, and in my mind it performs better, but I'd feel a lot better having positive proof to make sure it's not a placebo affect!
Dorf2point0
Richard
Anchorage, Alaska
2022 Explorer, 2005 Explorer, 2013 Escape
I thought the tuner came along with the Vehicle? The reason being it was then tied to your VIN? I would really like to figure all this tune out.. Thank you for the thread.. 😁🚗
ried
Carlsbad, CA
2022 Bronco
If the auto start/stop function remains off between drives, that's an indicator.
LethalPerformance
Jared
South Florida
www.lethalperformance.com
Right now these are the options available on the device for swapping gears and differentials.
  • Ability to change tire size up to BFG 37x12.5R17 KO2 size (579 revolutions per mile) [Additional modifications required]
  • Ability to change axle/FDU ratio up to 5.38
  • Enables upgrade of M190 to M210 front drive unit by reconfiguring DLCM module
LethalPerformance
Jared
South Florida
The devices are purchased separately as an aftermarket upgrade. They are VIN locked once you flash the cal to the vehicle. So you're unable to use the device on multiple different vehicle.
Here's a link to them. Let us know if you have any questions.
https://www.lethalperformance.com/f...ry-tool-2021-2022-bronco-2-7l-m-9603-b27.html
Dorf2point0
Richard
Anchorage, Alaska
Okay Group, not to beat a dead “Bronco” to death.. Is it better to have the ProCal installed by a Ford Dealer or buy the device, download, and tune your Bronco.. I say this because I can’t get confirmation that either of the Ford Dealers have much experience.. I’m an engineer, mechanic I’m pretty sure I can get it right
Dtrain72
Kinnelon NJ
You're right @Dorf2point0! I found the tuner in the car. And it's also clearly tach-ing higher. I'm not super blown away by the gains to tell you the truth (on the 2.3). Plus as @85crawlrunner said, auto stop / start is permanently disabled (almost worth it for that alone) :)
timhood
Tim
Several
This is not an issue at all. Simply open the tuner and load the stock cal back in if you're worried this may happen or gas goes to the moon. Then return to Perf tune whenever you want to be as you say "Mall Crawler" again.
How long does it take to change tunes?
CatMonkey
Lafayette LA
2023 Bronco, 2012 Shelby GT500, 2021 Shelby GT500
It's so easy a caveman can do it. All the tool does is download Ford's revised calibration to the PCM. Download the tune from the Ford Performance website, plug it into the OBD port and follow the directions the tuner gives you to load the tune. YOU are NOT tuning the truck. Your efforts will be to load Ford's revised calibration. There could be a few user selections where you have input, but it will be very limited. Tire size change would be one of them.
CatMonkey
Lafayette LA
There is no way to tell if your truck was tuned if you bought your truck used. They will not come with the performance tune from Ford. If you found the Pro Cal tuner in the console or glove box of your used Bronco, you might could assume it has a tune loaded. But if you have the device, you can plug it in see what happens. The device becomes pretty much useless to anyone else once the tuner has been VIN locked to a vehicle.
LethalPerformance
Jared
South Florida
Ford Performance discloses that to obtain the 3/36 warranty offered with their calibration the tune needs to be installed by a Ford dealer or ASE certified tech. You can install the tune by yourself but in the event you have a warranty issue and which you try and claim not having it installed by a Ford dealer or ASE certified tech my cause issues with you getting the claim approved.
mjohnso3
Marc
Atlanta
FJ Cruiser
Hi @LethalPerformance
I have a question regarding the tune and the requirement to run 91-93 octane to achieve the HP and torque gains. I understand the need to run the premium fuel to observe those gains but what happens if you run 87? Will the engine management control simply regress the timing and other parameters it changes like a stock engine and maintain the stock HP when you are using 87 gas? (which would be good if this is how works)Or, will this engine run the risk of pre-ignition/detonation with this tune on 87 gas? Thanks in advance.
