Introducing Vorsteiner Off-Road
Status
Not open for further replies.
Vorsteiner
Huntington Beach, CA
vorsteineroffroad.com
Ford Bronco
Defying the ordinary, we crafted a brand for adventurous drivers seeking uniqueness. Beyond aesthetics, our bold, inspired designs speak of daring exploration. With innovative, flow-forged construction, our wheels guarantee unmatched strength, conquering any road. Embrace the thrill of the open road, break free from the mundane, and stand out in style. Every journey is unique, so choose from our diverse range of sizes and styles that match your personality. Join our community of like-minded adventurers, sharing tales of triumph. When the need for adventure strikes, Vorsteiner Off-Road is the ultimate choice, empowering you to redefine exploration with confidence.
Ford Bronco Introducing Vorsteiner Off-Road VR 601 BL
Ford Bronco Introducing Vorsteiner Off-Road 17 VR 601 BL_updated centercap_4
Our lightweight technology produces wheels that are lighter in weight compared to a conventional cast construction, yet substantially stronger. The majority of surplus weight can be shaved by the use of less but stronger aluminum. In addition, we meticulously reduce the weight of the wheel utilizing back-pad pocketing as well as front and rear spoke pocketing.
17" Vr-601BL Baja Bronze
Ford Bronco Introducing Vorsteiner Off-Road 17 VR 601 BL_updated centercap_3
Ford Bronco Introducing Vorsteiner Off-Road 17in 601 BL Baja
17" VR-601BL Tungsten Graphite
Ford Bronco Introducing Vorsteiner Off-Road _601 BL
Ford Bronco Introducing Vorsteiner Off-Road 17 VR 601 BL_updated centercap_2
View our full collection of wheels compatible with the Ford Bronco here!
MJJ
Sean
Iowa
JL Wrangler Rubicon, Jeep Wagoneer, Colorado ZR2
What are the wheel specs? Size, weight, offset, price?
Vorsteiner
Vorsteiner
Ford Bronco
Wheel specifications vary by product.
For the pictured 17" VR-601 BL wheels at $325/wheel:
Wheel diameter (IN):17
Wheel Width (IN):9
Bolt pattern:6x139.7
Wheel weight (LBS):27.6
Offset (MM):+0
Backspacing (IN):4.5
Hub Bore (MM):106.1
Max load (LBS):2600
You can view our full collection of wheels compatible with the Ford Bronco here!
MJJ
Sean
Iowa
Wheel Width (IN):9
Offset (MM):+0
Hub Bore (MM):106.1
Max load (LBS):2600
Thank you
dangerfoot
Justin
Austin TX
www.dangerfoot.com
White Wildtrak 4dr
Thanks for posting up @Vorsteiner ! Guys, these are some of the most well made, lightest and proper stance options for our trucks.
Most people don't pay attn to the weight of their wheels and sacrifice performance, especially when going +1 on tire size.
I ran some VR601S on my full size truck and got compliments all the time! Definitely would buy for the bronco.
Ford Bronco Introducing Vorsteiner Off-Road 1000002885
Vorsteiner
Vorsteiner
Ford Bronco
Looking good!😎
huey
kevin
Ontario & Kentucky
would love to see more options on the offset!
Donkey
Tijuana
totalled
Wheel Width (IN):9
Offset (MM):+0
Hub Bore (MM):106.1
Max load (LBS):2600
Thanks for posting weights. No one ever seems to.
Vorsteiner
Vorsteiner
Ford Bronco
The VR-603s striking design blends rugged off-road aesthetics with a touch of luxury
Crafted by Vorsteiner Off-Road, renowned for their exceptional craftsmanship and quality, these wheels are built to withstand the toughest challenges. Whether you're conquering rough terrain or cruising through the city, these wheels are up for the task. You'll enjoy both style and peace of mind knowing they're built to last - the perfect blend of form and function.
Ford Bronco Introducing Vorsteiner Off-Road Untitled design (83)
Ford Bronco Introducing Vorsteiner Off-Road Untitled design (82)
Being constructed using flow forged technology, our wheels are substantially stronger than our competitors. Cast wheels tend to be less durable, brittle, prone to cracking and failure. With our flow forged wheels, you won't have to worry about any cracks when you're on the trail, desert, hauling or on your daily commute. The flow forging process we use creates very lightweight wheels compared to the competition. In the end, you end up with a wheel capable of handling higher load ratings than a cast wheel. With a flow forged wheel, you save about 25% weight compared to a cast wheel of the same size and spec. Lighter weight wheels equals reduced unsprung and rotational mass.
Ford Bronco Introducing Vorsteiner Off-Road Untitled design (81)
Ford Bronco Introducing Vorsteiner Off-Road Untitled design (80)
The VR-603 wheels elevate the aesthetics of your Bronco with striking Vorsteiner design and premium finishes. Learn more at vorsteineroffroad.com
Vorsteiner
Vorsteiner
Ford Bronco
Vorsteiner is thrilled to usher in the holiday season with a special promotion that aims to redefine your gift-giving experience.
Whether gifting to your loved ones or to your loved vehicles, Vorsteiner Off-Road has everything your Bronco needs for the holiday season.
Redefine your Holiday at Vorsteineroffroad.com
Ford Bronco Introducing Vorsteiner Off-Road Vorsteiner Off Road_Holiday 2023_Ads_SQUARE_2
Ninjak
Miami
That looks really good
Status
