- First Name
- Chris
- Joined
- Mar 18, 2022
- Threads
- 23
- Messages
- 447
- Reaction score
- 951
- Location
- Hemet, CA
- Website
- lobooffroad.com
- Vehicle(s)
- All of them
- Your Bronco Model
- Wildtrak
- Thread starter
- #1
Lobo Off-Road is proud to introduce TREMRR Wheels to the Bronco and 4X4 community! TREMRR Wheels have been developed by friends of ours in the off-road racing culture of the desert southwest, and these wheels provide a great mix of strength, aesthetics and some really cool features for off-roaders!
So Far TREMRR offers 3 distinct wheel designs (Shaker, Aftershock and Impact) in three popular finishes (Satin Black, Graphite Gray and Gloss Gold). Each of these are available in 17X8.5, in the Bronco's bolt pattern of 6 on 5.5, with 0mm offset, and they are lug-centric. Here's a closer look at each:
AFTERSHOCK
SHAKER
IMPACT
Note that they are also available in 20X9 in most of these style/finish combinations.
Whether you’re on the highway or off the grid, TREMRR Wheels get you where you need to go with durability and next-gen design aesthetics. No matter which terrain you encounter, TREMRR Wheels will allow your vehicle to dominate any landscape your heart desires. Features such as Heavy Duty Construction, TREMRR’s exclusive Tire Seat Channels and Dual Air Filler Ports make these the most capable and versatile wheels available for your 4X4, rock crawler or overlander. It doesn’t matter which wheel style you choose because every wheel in our inventory would allow your vehicle to dominate the great outdoors.
DUAL VALVE STEM HOLES
Every Tremrr wheel comes with dual valve holes for the convenience of off-roaders, overlanders and anyone who airs up and down frequently. Your main valve stem and TPMS sensor will occupy one, and your choice of rapid air-down device may be fitted to the other (sold separately; wheel ships with standard TR412 rubber valve). We recommend the RPV Fast Deflating Rapid Precision Valve Stems from Apex.
TREMRR TIRE SEAT CHANNELS
Every Tremrr wheel features a special bead-retaining channel on both the inner and outer rim of the wheel.We have developed our wheel to have a special mounting feature on both bead areas. The Tire Seat Channel helps prevent de-beading when off-roading at low air pressures for traction or comfort. When mounting the tire, It has to slide up a 45 degrees transition that is 3mm taller than the barrel of the wheel and then snaps into place at the bead. The face of the bead sits against the lip of the wheel and the inner bead now had a 3mm flat wall that reinforces its position in place.
Thanks for Checking out TREMRR Wheels and Lobo Off-Road, your exclusive online TREMRR Wheel retailer!
AFTERSHOCK
SHAKER
IMPACT
