Firefight911
Phil
Simpsonville, South Carolina
2022 Ford Bronco 4-door Wildtrak, Eruption Green
Ford part# of the keypad?
hold on. There are different part numbers based on your having, or not having, remote start on your key fob. Make sure you get the correct one.
everything is available at the Ford accessory site.
TripleB
Georgia
2021 Ford Bronco Base Sas 2.7L, 2026 Ram RHO
That's what I can't figure out. There's conflicting info on the internet.
KB3Z-14A626-A
or
KB3Z-14A626-B
Firefight911
Phil
KB3Z-14A626-A
or
KB3Z-14A626-B
Pretty straight forward… A is without, B is with.
Ford Bronco Installing Keyless Entry Pad in the fuel door C77B393B-1715-4906-B653-7B19F54337B7
TripleB
Georgia
The dealer list says the opposite, same with some of the internet sellers. I'm looking for a response from someone that has experience purchasing this item.
Firefight911
Phil
Well, allow me to provide some input.....see above post. I installed this on our Base months ago. Base - Without - A
Not sure if you are aware, this must be done at a Ford dealer. It requires the FDRS system to get it recognized and assigned to your vehicle. It is not a Forscan option and you can not do it yourself without FDRS.
Firefight911
Phil
TripleB
Georgia
Great, so your base was a manual trans?
Firefight911
Phil
No, an automatic.
Do not confuse remote start in this context. Remote start is standard on 100% of EVERY automatic transmission Bronco made. All of them! This feature is available through the Ford Pass app. The difference in keyless entry keypad options is differentiating those vehicles that have a higher trim level that comes with a remote start on your keyfob.
Manual transmission has NO remote start, regardless of trim level.
BadlandsA51
Craig
Kansas
23 Badlands, Sasquatch, Lux Pkg, 72 Ranchero GT
It’s a brilliant idea, even though with Ford pass on phone I’d probably never need it. Something to think about!
Remember, though, Ford Pass only works if you have cellular service. The kind of places I like to go don’t have.
