Installed Mabett back seat/cargo area ceiling light
vbrad26
Vance
FL
VW's, an old Range Rover and now a Ford
Same with the connector issue. But it went in enough to work and I don't think it is going to back itself out.
Deano Bronc
Dean
Winona Lake, IN
2022 Badlands
Yep, I did the same. Mine was in tight enough, I don't think it will come out. If I was really worried about it, I would just put a little tight around the connection.
brian626
Chandler, AZ
2023 Bronco Wildtrak, 2010 Porsche Boxster S, 2025 Tesla Model 3
Mine arrived yesterday and I installed it today! I agree that the hardest part is removing the factory light, but eventually it pried out with plastic trim removal tools. I added thicker 3M double sided tape over the 3 areas of tape that came with the light. The new light popped right into place easily and is so much brighter! Thanks Mabett!
LordElberon
Pittsfield
Na
Doesn't look like it fits the 2 door models? Wonder what the difference is?
mjcutri
M
Lisbon, Portugal / Pittsburgh, PA
2023 Bronco HE
The roll bar trim piece is different on the 2-door and the 4-door...
2-door
Ford Bronco Installed Mabett back seat/cargo area ceiling light 1680701511655
4-door
Ford Bronco Installed Mabett back seat/cargo area ceiling light 1680701544349
millerranch
George
2024 Bronco
Arrived yesterday. Installed this morning. Super easy swap. Hardest part was prying the oem light out.
Big improvement.
I installed this - thank you! Super easy. However, The switch doesn't work.. does yours? I can't change the brightness or turn it on or off with the switch. Works when I open a door and goes off automatically, even while I am still loading.. and need it ON !
