Installation: Baja Designs Triple Fog Kit
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
Brian came stopped by our shop here in Lindenhurst, NY today for one of our Baja Designs Triple Fog Light Kits.
He chose a set of Squadron SAE for his main fog lights. A pair of Squadron Pro Driving/Combo for off-roading (these are both a spot and a wide pattern) and a set of S2 Pro in Spot for down range. We aimed the SAE fogs so that they fall below the low-beams. The Driving/Combos were aimed so that the spot portion fell with each low beam. The S2 Spots however we aimed slightly inwards more so that both spots were side by side but at the same low-beam level. This will help the spots go down range.
As part of our kit he also received our (USA Made/Stainless Steel) KR Off-Road mounting brackets and our CrystaLux Upfitter Harness. He chose our open style bracket which saved him a few bucks and gave him a more agressive look. Our harness plugs right into the back of each light. No need for any adapters to convert connectors. The other end of the wire is crimped onto the existing upfitter wires using our included heat shrinkable weatherproof wire connectors. This makes for a nice clean installation!
https://www.4x4truckleds.com/baja-d...ckets-for-2021-ford-bronco-hd-modular-bumper/
Ford Bronco Installation: Baja Designs Triple Fog Kit Fogs1
Ford Bronco Installation: Baja Designs Triple Fog Kit Fogs2
Ford Bronco Installation: Baja Designs Triple Fog Kit Fogs3
