Install Gatorback rear flap question
threeonone
threeonone
Canada
Jaguar
No drilling required. Extremely easy.
How did you install without drilling? The gatorback YouTube video and instructions both say you have to drill for both steel and plastic bumper. I have the steel bumper and I had a look at it and it definitely looks like it needs to be drilled.
MillerAndCheeto
Robin
Calgary, AB
2 Door Cyber Orange Wildtrak Sasquatch
Sasquatch Broncos come with a small "mini flap" that essentially extends the rear bumper out a few inches to match the width of the Sasquatch fender flares. Find a pic of a Wildtrak rear view and you'll see it. This is pre-drilled and installed in the factory. I just re-used those mounting holes.
604Bronco
British Columbia
www.bronco6g.com
2024 Toyota Tundra TRD Pro
Can you confirm whether or not you had to drill into your rear bumper for the install?
To be totally honest, I didn't install them myself. But here's a picture of my rear flaps, if it helps - Looks like it's drilled into the bumper though and seems pretty sturdy. I have a Sasquatched Badlands.
Ford Bronco Install Gatorback rear flap question IMG_1559
chtucker
Kirkland, WA
FJ Cruiser
Yep, they should be drilled with self tappers. A tiny drill bit to get the started and a ratchet works.
I did it with a regular drill, a right angle drill be slightly easier, but it's not necessary. I used a regular socket/ratchet to finish it off.
threeonone
threeonone
Canada
Jaguar
Ah ok got it. I have a non-sas badlands
MillerAndCheeto
Robin
Calgary, AB
Gotcha. Yah, do the drilling then. The factory does it for the Sasquatch package so it's not like it's going to hurt anything!
