Inconsistent left/right steering feel?
Palmermc
San Jose, CA
www.markpalmer-design.com
2021 Bronco First Edition
I just picked up my FE last week and have logged 250 miles. I’ve noticed something that feels slightly off about the steering feel.
At first I thought what I was feeling may be an alignment issue as I thought I felt it pulling slightly to the left or generally wandering a bit when trying to hold center.
After spending some time today studying the feel, it seems like it’s a bit harder to steer to the right from center, and also takes more force to hold a given steering angle towards the right, compared to steering to the left from center. The force difference isn’t huge - maybe 5-10% harder, but it’s enough that it feels like a minor annoyance. Aside from feeling inconsistent when turning left vs right, I think this is contributing to the sense of wandering when holding center, as minor back and forth wheel adjustments while holding center feel a little different between left and right.
There’s also a chance I could be losing my mind and there is no issue , or that things just need to break in. I’m about to head out on a long trip from the Bay Area to Joshua Tree, so I’m just hoping there isn’t a larger issue brewing here.
Let me know what you thing or if there’s anything I should check. Thanks!
Lifeliberty
Moonbeam👀
Columbus, OH
I'd first check tire pressure when cold
Lifeliberty
Moonbeam👀
Columbus, OH
At that point could be a lot of things.
Suspension
One tire/wheel being a little off but still in spec
Wheel bearings
Alignment
I'd report it to dealer and let them look at it
PowPow
PA
2018 Tahoe
is it the lane keeping assist?
If you're driving and start to wander left or right, you'll feel it kinda 'pull' you back into the middle.
Lifeliberty
Moonbeam👀
Columbus, OH
I'd Also check power steering fluid, and since so much is electronic anymore, check battery cables tightness
Check owner manual for troubleshooting.
Check the things you can, otherwise send to mechanic
talbot
Calgary
2dr BL AMB
was going to suggest turning this off and see if there's a difference
69BroncoX302
1969 U15, 2021 First Edition
My FE kinda has the same feelings, like my 69 does. I am just going with the big tires and short wheelbase. I drove 1800 miles straight and had zero abnormal tire wear so I am not worried.
Rakkasan187
NW Arkansas
2021 FE Bronco, 2020 Ram 2500
My FE has the same feeling, but I think it is due to having lane keep assist on.
