- ORACLE
- Mar 13, 2020
- 19
- 616
- 2,003
- New Orleans, LA
- Website
- oraclelights.com
- Bronco
- Undecided
AVAILABLE NOW!
ORDER HERE: https://www.oraclelights.com/products/bronco-triple-fog-kit
Designed to work with the Factory Steel “MOD” Bumper on the 2021+ Ford Bronco, this LED Fog Light kit is a quick and easy way to add functional forward-facing LED lighting to your vehicle. The simple bolt on installation uses factory bolt locations and provides significant visibility through advanced optics without causing glare which can blind other drivers.
Typical installation time is under 30 minutes and can be successfully installed using common hand tools by even the most casual enthusiast. This is a complete kit including 2 assembled steel housings, 6 LED Emitters, Wiring Harness, and all necessary hardware.
LED Specifications:
- DOT-Compliant LED Fog Light Modules
- 6000 Raw Lumen Light Output
- Total Wattage: 90W (45W Per Side)
- Total Amp Draw: 3.6A @12V DC
- Advanced Optics Design for Optimal Visibility
- Precision Beam "no glare” output design
- Aluminum Anti-fog Breather Valves
- Molded IP68 Waterproof Connectors
- Waterproof Rating: IP68 Ingress Protection
Features and Benefits:
- High-Powered LED Lighting from 6 Emitters
- Easy Install- No Drilling/ Modifications Required
- Switched Relay Wiring Harnesses Included
- Emitters Feature Blacked-Out Design
- High Quality ⅛” Thick Steel Plate
- Rough Powder Coat Finish
- Mounts using Factory Hardware
- Designed, Engineered and Assembled in the USA
Will be Available in White and Yellow LED .
MSRP: $359.95/ Set
Availability: EDIT: AVAILABLE NOW!
ORDER here: https://www.oraclelights.com/products/bronco-triple-fog-kit
UPDATE: Demo Video Below...
LED Specifications:
MSRP: $359.95/ Set
