Sold: New Hampshire ICON Billet UCA DJ Pro Kit
decummins
Daniel
New Hampshire
2022 Bronco Wildtrak
$1000.00 + Shipping.
I am selling the following kit which retails for $1469.95
https://iconvehicledynamics.com/accessory/18796/icon-accessories-21-up-bronco-billet-uca-dj-pro-kit/
This is an open box item. Never driven. These were briefly installed on my 2022 Wildtrak and taken off. Only one side was installed. Long story short - they were interfering with my King Shock reservoir hoses at 3/4-Full droop.
The king shock kit I was trying to pair them with was the King Front Coil-Over OEM Performance series w/adjuster 25001-392A.
I was very surprised that this pairing caused rub as I was thorough in my research. I spoke to King and found out from their engineering team that recent versions (gen2) of this shock kit moved to a larger diameter reservoir hose and fitting. As a result the new egress angle can cause clearance issues with some aftermarket control arms - especially the thicker billet arms. There are no issues with stock UCA.
I also spoke to baja kits to explain my compatibility challenges as I would move to their UCA only if they are compatible with the gen2 king shock. They are now following up with king on this. It would appear that many of the UCA manufacturers may have originally designed their parts against the gen1 version of this Bronco King shock as evidenced in many of the videos and photos showing the gen1 king shock.
The reseller I purchased these ICON UCAs from is not accepting a return. So I am left to sell these while I work on a solution that doesn't require any modification.
If you are interested in these - please contact me.
Ford Bronco ICON Billet UCA DJ Pro Kit IMG_3339
Ford Bronco ICON Billet UCA DJ Pro Kit IMG_3340
Ford Bronco ICON Billet UCA DJ Pro Kit IMG_3341
The difference between the gen1 king shock (smaller hose and angled fitting) versus the gen2 king shock (larger hose and different fitting)
Gen 1
Ford Bronco ICON Billet UCA DJ Pro Kit 1671560350919
same shock but gen2
Ford Bronco ICON Billet UCA DJ Pro Kit 1671560391601
.. and the rub with ICON UCA + King gen2
Ford Bronco ICON Billet UCA DJ Pro Kit 1671560464430
popo_patty
Caleb
Sacramento
2021 Bronco/1996 Jeep XJ/1957 FC-150
When did the shock change from gen 1 to Gen 2? I can’t find anything
Evolkidbell
Northern Colorado
1966 Bronco, 2013 F-150
I received a set last August that has the Gen1 set up. Was told it was only produced for a free months. Had to get new reservoir brackets that “sort-of” help in fittment.
popo_patty
Caleb
Sacramento
I received a set last August that has the Gen1 set up. Was told it was only produced for a free months. Had to get new reservoir brackets that “sort-of” hey in fittment.
Awesome thanks! Yea so far I’ve seen a post showing the Gen 1 shock not fitting with SPC (curious if the Gen 2 would fit). There is also a post showing the Gen 2 shock not fitting Icon Billet arms. I’m for sure going to address this in my suspension video coming out in April going over Icon, King and Radflo all on 37’s
Evolkidbell
Northern Colorado
BTW. This is a good deal for literally brand new UCAs. Someone needs to jump on these.
