IAT2 / ACT2
B22-2023
Houston
I did a quick search and didn't find out - does Forscan or Forscan Lite log these values? I know ProCal and other tuners do, my JB4 doesn't - and I don't have my laptop handy to log into & connect Forscan this week. Thanks!
I don't know about these specifically, but in my experience Forscan has ~much~ more available data than the ProCal module does. ProCal seems to only look at a couple of the modules, Forscan can see everything your adapter can see.
So I would bet if ProCal can see it, so can Forscan.
Have not played enough with Forscan Lite to verify on that though
B22-2023
B22-2023
Houston
I was able to Forscan today after all and both IATs are there, so that’s easy. Burger is still indicating I can maybe get both in JB4, it’s just easier to log there while driving.
B22-2023
B22-2023
Houston
Success with Forscan Lite - I’ll put it on the other thread but for a $40 OBD and $7 app, I got all the otherwise elusive things displayed and logged via iPhone, on a BT connection :
Ford Bronco IAT2 / ACT2 IMG_0965
Nice. I’ve thought about getting Lite. I have the free edition but it’s very underwhelming.
The app that comes with the MX works for the most part and I only use it very occasionally. Although maybe I should look into using it more often… $7 isn’t too steep
B22-2023
B22-2023
Houston
I’ll put this OBD dongle in the Forscan thread later and it’s not the one they recommend, but a lot cheaper and it works well.
Apart from the sticker it looks Identical to the MX. Funny.
B-Dog15
Brandon
Covington, Ky
2025 Base 4-Door
What all does the free edition let you do? Main thing I want to be able to do when the time comes is change tire size.
Reset DTC codes looks like about it, and I didn’t even play with it long enough to figure that much out
To make any changes to anything though you need the PC version (or ProCal), not even the paid Lite edition can make edits
