IAG winch mount - anyone installed yet?
Hemisfear
Bronco Bob
Lotusland
2014 Focus ST
Hi,
Hemisfear, I've been trying to find these, but w/no luck.
Anyone else you know of who might sell something like this.
You wouldn't happen to have any dimensions for these spacers by any chance?
Thanks.
Stacked large fender washers should work easily enough, where have you looked, I got mine from Epic Adventure Outfitters, but I think they were a left over special order. Since 4WP owns Poison Spyder, they should be able to help…
Hemisfear
Bronco Bob
Lotusland
2014 Focus ST
Questions about your Winch setup, if you wouldn't mine answering?
I have my IAG winch mount sitting right next to me ready to be installed.
When it comes to the installation, is the point when the IAG mount attaches to the Frame Ends strong enough to handle the Force put upon the assembly when under load.
There are these additional bracket pieces available:
Then I'm also looking at this Superwinch SX10SR 12V DC 10,000lb Synthetic Rope Winch, which sadly is Chinese made, but the problem, WILL IT FIT?
Also too, would the old Warn M8000 Winch fit, since it is a plain and simple design, which I've owned a couple of, but sadly is only 8000 lbs, while the recommendation for the Bronco is at least a 10,000 lb.
I’m planning on adding something similar to reinforce but Haven’t yet.
GoHack
Palmdale, CA
'25 Bronco, 2.3L 4-Cylinder, 7 Spd. Manual, 4 Door
Ya, I've checked, but w/no luck.
I was also thinking about going w/the fender washers instead.
As for that Frame End Reinforcement I have posted, I finally got the set pictured. Need to install.
Still keeping my eye open for something better though.
Thanks!
