vzqhsg
MI
F-150, Badlands
Received the IAG Para-Hex grill today in the mail and had to throw it on right away. I orderd Matte Black and think it looks pretty good with Ox White. It doesn't give Jeep angry eye vibes like some were worried about.
Install was easy straightforward, quality seems good. My only knit pick is the font for the letter "B"
Still have to wire the lights to the upfitters, might tint the lights.
Other mods:
Fifteen52 Range HD, 17x8.5, et 0
Fabtech 4" lift
Tires are Geolandar A/T 37"
Are the 3 amber lights just reflectors or actual lights? Are they plug and play into the harness?
craq5
craq5
Ford Bronco 2022 Badlands
They are LED lighrs. I wired mine to my upfitter switches black to ground, red to switch wires.
You could also wire to your fuse box. Red to fuse box and black to ground.
WillinMA
Will
Groton, MA
2021 Wildtrak, 2025 BRaptor, 2025 G63, 2020 Lambo Huracan Spyder
Here's the grille installed with OEM letters (with overlays) in matte black. Fit of grille is good and definitely gives a different look than the gloss wildtrak grill I had on before! If you are following the video on moving over the letters, make sure you buy narrower screws than the ones that come with IAG kit of hardware!
Ford Bronco IAG Para-Hex Style Front Grill - installed pics grill1
Ford Bronco IAG Para-Hex Style Front Grill - installed pics grill2
Ford Bronco IAG Para-Hex Style Front Grill - installed pics grill3
craq5
craq5
Looks good with OEM letters!
ahtussey
Abbey
Maryland
Ford Fusion Sport
The hubs & I got the grille on tonight and I absolutely love it! Used the supplied aftermarket letters and there is a difference between it & OEM but thinking about getting black overlay letters? 🤔
Ford Bronco IAG Para-Hex Style Front Grill - installed pics PXL_20221203_225600448
WillinMA
Will
Groton, MA
I think the overlays will be made for the OEM letters and since the ones that come with the grille kit appear to have narrower slits on the B, R , and C it could be that the overlays do not fit properly. It wasn’t too bad swapping the letters to the OEM… might be easier than trying to sort out the aftermarket ones!
ahtussey
Abbey
Maryland
Ford Fusion Sport
Yeah you may be right. I was hoping for some sort of white border around but perhaps not. Dang it! It'll be another few weeks before I have time to swap letters so I'll keep this for now. Thank you for your opinion!
emaier
eric
ca
Ram 1500 Laramie
I installed the gloss black with factory letters today
before and after
Ford Bronco IAG Para-Hex Style Front Grill - installed pics 20221204_153958
Giordiesel
Frank
New Hampshire
2019 Ford Ranger
Other mods:
Fabtech 4" lift
looks nice, I’d like to find the running light wire to tie it into, that way there, it will light up the three when I do a remote start and that will leave the uplifted switch available for something else.
greygirl
Charlotte, nc
2022 Badlands
Other mods:
Fabtech 4" lift
What running board did you put on?
Andrew
Ohio
2022 Ford Bronco
Ford Bronco IAG Para-Hex Style Front Grill - installed pics D1AE4D4E-146C-4CD0-A510-35404E26CDA1
Installed my gloss finish tonight! Had trouble with the amber lights then realized it may have been stupid on my part. Do all 3 amber lights need to plug in to the wire harness? I only plugged in the middle light and that’s the only one on. Seems pretty common sense now, but before I take it apart I wanted to verify with someone.. 😅
BroncoFanTX
2022 Ford Bronco, 2016 Ford Edge, 2010 Ford Fusion
I think my Badlands stock grill looks great!
As pointed out, the B and R letters on the IAG grill don't look right.
What didn't you like about your Badlands stock grill?
craq5
craq5
Nothing wrong with the badlands grill at all.. Just like almost every post on B6G everyone just trying to make their Broncos different, fender flares , wheels, Bronco Script badges, bumpers, vehicle wraps. Etc.....the grill is no different.
buck_6G
Austin, TX
Toyota Tacoma TRD Pro
I installed mine today. Love it!
Did you install an Oracle grille light kit on top of the IAG Para Hex grille, or does the IAG grille come with illuminated letters? Guessing the former, since your B and R don't have the super tiny holes I see on IAG's site, but wanted to confirm. It's a really great build you have.
