IAG Gloss Black Grille installed
O-BRONCO-O
Jordan
Southern CA
Swapped out my Badlands grille with an IAG gloss black grille. Bought an OEM camera housing and Bronco letters to finish it off.
Fitment of the grille is 8/10. It required some flexing to get all the clips to line up. Top corners above the yellow side markers had a small gap that I do not remember being there before (See photo) maybe I’m wrong.
Ford Bronco IAG Gloss Black Grille installed BAA57E5C-4C7F-4CF3-834F-7480DC5BAC98
Ford Bronco IAG Gloss Black Grille installed imag
83XLT
Carl
Cincinnati
22 EG Big Bend 2.7
I think it looks great. it's basically a glossy wildtrak grill right? is it cheaper than OEM wildtrak?
O-BRONCO-O
O-BRONCO-O
Jordan
Southern CA
It was about the same price as the OEM grill. But the OEM one comes in a matte black primer only. I searched for companies to paint the grill and got estimates anywhere from $200-$1500.
2020FordRaptor
Ty
Nevada
2020 Ford Raptor
Looks awesome!
O-BRONCO-O
O-BRONCO-O
Jordan
Southern CA
Thank you. I'm assuming it only comes primed?
Yeah just primed unfortunately. I’m going to get some paint and clear coat down the road and do it myself since it’s just a small part. Touch up direct has Ford gloss black in rattle cans. Wouldn’t paint a hood with it… but the small camera cover should be fine
WheresMyBronco
Los Angeles
2023 Badlands
You could try some gloss black vinyl as well. Mine was originally grey (swapped my Badlands grille for a Wildtrak grille) and I wanted to try vinyl out before painting it just to see if it'll work. I used 3 pieces in total, one for the front/top face and one one piece for each of the sides. The corners aren't perfect but you can't really tell.
Ford Bronco IAG Gloss Black Grille installed 20230201_212716
Ford Bronco IAG Gloss Black Grille installed 20230201_212722
Ford Bronco IAG Gloss Black Grille installed 20230201_212727
O-BRONCO-O
O-BRONCO-O
Jordan
Southern CA
That looks clean! I’ll give that a shot. Thanks
SubmarineNuke
Richard
Houston, TX
twitch.tv
Bronco Wildtrak
if @IAG Performance would sell their raptor or diamond grill in white I'd be all over it. (especially that raptor grill)
IAG Off-Road
JJ
Westminster, MD
www.iagperformance.com
SubmarineNuke
Richard
Houston, TX
twitch.tv
Bronco Wildtrak
thewodg
Massachusetts
A4
I am contemplating making this change (swapping a wildtrack style grille with my badlands). Can I ask why you need a new camera housing? Aren't the cameras in the same locations on the wildtrack and badlands grilles?
O-BRONCO-O
O-BRONCO-O
Jordan
Southern CA
You can use the same camera housing. They are the same part number.
