how topless can you go?
joez
parts unknown
bronco
Does anyone know if you can just take off the rear most part of the top, and keep the front sections in place?
Also it sounds like you can order both a hard top and a soft top. Is it possible to have both on at the same time (do you need to remove the soft top if you want the hard top on). Just trying to figure out how much storage space I'll need.
EcobeastRyan
Ryan
New York
17 fusion se
You can’t have both tops on at the same time. Hard or soft. No clue about removing just rear roof section
Garemlin
Delaware
Dual top is just that. Two tops. You use one or the other. As far as keeping the panels in place with the rear section off that remains to be seen. It depends on how they actually attach. With the Wrangler they latch in the front and screw in to the crossbar. With the fact that there is no crossbar they probably attach at the sides somewhere. So it's feasible that they could stay on with the rear off.
Personally if I was just looking for shade I'd throw a bikini top or sunshade on. Still get the air without the sun beating down on you.
Rogues Gambit
Eatontown, NJ
'19 Ram Rebel, '07 A4 Quattro
Ford Bronco how topless can you go? 1595547445364
Ford Bronco how topless can you go? 1595547458735
Ford Bronco how topless can you go? 1595547513618
Ford Bronco how topless can you go? 1595547523180
Ford Bronco how topless can you go? 1595547617204
Ford Bronco how topless can you go? 1595547688302
Ford Bronco how topless can you go? 1595547737184
Oh, we're talking that kinda topless
