How to replace fog lights on Capable Bumper?
Jmanrex
2023 heritage 4door
I finally got around to trying to install ss3 into the capable bumper. You will either have to drill a side hole in the plastic, which I am leaning towards or magically find the correct bolt and nut replacement, there isn't much room to adjust or tighten the mount. I had the whole "pod" apart to install and there is no easy way except to drill a hole to tighten the side hardware
Side note, pod is 2 pieces and can come apart. See last pic.
Ford Bronco How to replace fog lights on Capable Bumper? PXL_20220604_170058079
Ford Bronco How to replace fog lights on Capable Bumper? PXL_20220604_170050396
Ford Bronco How to replace fog lights on Capable Bumper? PXL_20220604_163007846
Tarheel_Wes
Wesley
FJ
So, I am doing mine right now....
I got the kit from @Diode Dynamics that is advertised as the replacement for the factory fogs on the STANDARD bumper. It comes with the little bracket.
Where are you saying you need to drill?
This is what I did:
When you put the bracket on the SS3 and drop it in....it does bump into the plastic housing and doesn't sit as "flush" as the round factory fog.....
What I did was put some m6 nuts I had lying around to work as "spacers", and then just bolted the ss3's in using the factory hardware.
I also have the ssc1's to try in the side pocket. Because of the curvature of the housing, it looks like the only way to make that work is to drill the top and mount the bracket on the top side. looks like there is pretty easy access.
This is ongoing project now so I'll post updates as I go.
But heres' a few pics and a pic of the ss3 installed (with those spacers I used), it's in there tight.
Ford Bronco How to replace fog lights on Capable Bumper? tempImageBnhqBC
^^ Factory Fog sits flush
Ford Bronco How to replace fog lights on Capable Bumper? tempImagezTx7aO
SS3 has a little gap (like maybe 1/4", due to the round plastic curve that it sits on top of. You can use spacers like I am, or you can be braver and trim the plastic. I didn't wanna trim so I used nuts as spacers)
Ford Bronco How to replace fog lights on Capable Bumper? tempImagetI99PY
^^^ nuts used as spacers (your factor T25 torx bolts don't thread through these nuts, don't be confused by that, they are literally just acting as like bump spacers)
Ford Bronco How to replace fog lights on Capable Bumper? tempImageofSOLa
^^ SS3 after tightened down
Ford Bronco How to replace fog lights on Capable Bumper? tempImageUN09ua
^^ Potential spot for the SSC1
Tarheel_Wes
Wesley
FJ
ok..
here we go....
Ford Bronco How to replace fog lights on Capable Bumper? tempImagevB1eVN
Tarheel_Wes
Wesley
FJ
Ok
Let’s get it wired
Ford Bronco How to replace fog lights on Capable Bumper? D1392705-BDE1-4EF5-8C25-DAA9C04FF490
Ford Bronco How to replace fog lights on Capable Bumper? 757613FA-320B-4389-879D-BFAC0902CF4A
Tarheel_Wes
Wesley
FJ
Ok
Wiring is good
Here’s one pic with the yellow fogs and white spots on
One pic with just the amber backlights on
The SS3 fogs are operated by my factory fog switch
The white c1 spots I used aux #5 and I tied all the backlights together and ran them to #6
Ford Bronco How to replace fog lights on Capable Bumper? 628D287C-A0F5-4789-88CD-EB029C0D2032
Ford Bronco How to replace fog lights on Capable Bumper? 88928BCB-EFA8-4203-BD5E-8421B6F21744
Tarheel_Wes
Wesley
FJ
All buttoned up
Now just have to test the beam pattern tonight against a wall. Fingers crossed I won’t need any adjustment
Ford Bronco How to replace fog lights on Capable Bumper? A8BCAFDD-09DC-4091-A399-48EF9478579D
Ford Bronco How to replace fog lights on Capable Bumper? 5D039658-C4C0-4870-98DB-BC485DE746F7
Ford Bronco How to replace fog lights on Capable Bumper? 3E4EEE85-B650-44EC-AF32-7B4313F5ED58
mhorvath1218
mhorvath1218
2022 Bronco Badlands
All buttoned up
Hell yeah! That looks awesome! Great job getting the ssc1’s in too. Looks like I’ll be ordering a set for mine as well, but I’m going to do the opposite colors since I have yellow ssc2 ditch lights and white elites on the way already.
Any tips on removing the factory fog and housing?
Tarheel_Wes
Wesley
FJ
Yea I’m about to post a new thread trying to detail it all step by step. I’ll link it here.
mhorvath1218
mhorvath1218
Tarheel_Wes
Wesley
FJ
