How To: Install D-Switch 8-Channel Switch Panel | Diode Dynamics
Diode Dynamics
John C.
St. Louis, Missouri
www.diodedynamics.com
Ford Bronco
Take your vehicle’s setup to the next level with the Diode Dynamics D-Switch. This advanced 8-channel switch panel gives you full, customized control over any 12V accessory that you want to wire up. And as you might have guessed, our engineers have also tailored it specifically to be the most functional and effective controller when it comes to your lighting setup.
Learn more here: https://www.diodedynamics.com/diode-dynamics-d-switch-8-channel-switch-panel.html
If you have questions, please don't hesitate to contact us directly at our headquarters for a team member to discuss options for your ride.
Hours: Monday-Friday 10 a.m. - 5 p.m. CDT
Email: [email protected]
Phone: 314-205-3033
NMWildtrak
Keith
Rio Rancho, NM
2022 Wildtrak
Is Carplay compatibility planned at some point? That and cost are really the only things that the Garmin has on you.
Diode Dynamics
Diode Dynamics
John C.
St. Louis, Missouri
Ford Bronco
Unfortunately, Garmin is currently the only switch panel on the market compatible with CarPlay. This is because their app is classified as a navigation app, which allows it to appear within CarPlay.
The D-Switch app—and other leading switch panel apps—don’t fall under that category, so Apple doesn’t permit them on CarPlay. That said, Android Auto compatibility is in development and will be available in the near future since Android’s system allows broader app types.
NMWildtrak
Keith
Rio Rancho, NM
2022 Wildtrak
Thank you for the response. Just an idea but perhaps you could call your app, "Illumination Navigation" to get around the Apple guidelines :wink:
Diode Dynamics
Diode Dynamics
John C.
St. Louis, Missouri
Ford Bronco
There is a big demand for CarPlay compatibility! If we can bring a solution to the market, it'll be formally announced. Thanks for the feedback and support!
