How to add a Keyless Entry - The Supereasy Edition.
mpeugeot
Without any dicking around from the dealer, order the following:
Keyless Entry Keypad KB3Z-14A626-A (FOR BRONCO WITHOUT REMOTE START)
Keyless Entry Keypad KB3Z-14A626-B (FOR BRONCO WITH REMOTE START)
J2534 Adapter:
https://www.amazon.com/VXDIAG-Nano-Ford-Mazda-V100/dp/B01EFWPAN0
VXDiag Software:
http://www.vxdiag.net/managecenter/download/vxdiag.zip
And the Ford FDRS Software:
https://www.motorcraftservice.com/diagnostic/Support?channelId=51&categoryId=304
And it is super easy to do with FDRS Software from Ford's website. You need to get a 2 day license for the software ($50).
You will need the Keyless Entry Pad, internet access, the FDRS license, a Ford login account, and Internet access in order to install the Keyless Entry. NOTE: When you buy the license it doesn't make your account... or it did not for me. So that was an extra step. (I actually installed all the FDRS,FJDS, IDS, and VCI software)
I installed the license in FJDS only to find out that FJDS doesn't work on the Bronco.
After intalling the FDRS software , the VXDiag Software, and the J2534 Adapter;
Start the FDRS software.
Open FDRS, log into your account using FDRS
Look for the Keyless Entry Programming section and download that routine from the net.
Make sure the vehicle is off, and start the module, follow the instructions.
Power on vehicle when prompted.
Enter the six digit serial number when prompted.
Test the Keyless Entry Lock when prompted.
Turn off the vehicle when prompted.
Test the entry code.
Program your new personal code if desired.
Test your personal entry code
press 7-8/9-0 to lock your vehicle.
You are done.
It was really quite easy! Hope that helps anyone who wants to tackle this.
Here is a video on FDRS keypad programming:
It works that easy!
LoneRider
Wayne
Marysville, WA.
2022 Bronco
My dealer charged $90 to program, another one quoted $300-$400 but I don’t think she understood what I was asking for.
TullyBronco
Tyler
South East Virginia
17 Mustang, 02 Explorer
I didn’t get the keyless entry with my order but my dealer said they would do it for something like $100. I guess if you were quoted something ridiculous this would be a fun project to do!
mpeugeot
mpeugeot
Great write up, but why would you spend that much money to do it on your own? Does the dealer charge that much for installation?
Because I will be able to help others out for less. Plus, I want the ability to reprogram ECU's and other modules.
As I will likely do this in retirement for people who need custom reprogramming in order to do things like swapping steering racks or enabling front lockers on Broncos that didn't come with the front locker but now need them to be enabled, etc.
Aztec1382
Sam
F350
Thats a good write
My dealer charged 190
I would have gone your route instead
Rusty Sheckelford
Rusty
LA
You're doing God's work, my friend.
Hell yeah
etmccaus86
Evan
Motor City
'22 BaseSquatch
My dealer not only wants an egregious amount to do any sort of programming, but is so backed up on the service side of things...it would take weeks for them to spend all of 20 minutes with my vehicle.
etmccaus86
Evan
Motor City
'22 BaseSquatch
Not to mention I'm met with a hefty amount of skepticism every time I specifically ask for anything.
"You want a calibration for what now? An accessory? Did we install it? No? Not sure we can do that, then."
My kingdom for a service advisor who can recognize when someone isn't completely ignorant about their vehicle.
mpeugeot
mpeugeot
Exactly!
Also, I do know that this really does open up a lot of possibilities with regards to what can be done with the Bronco that FORSCAN simply cannot do yet. There are likely all sorts of calibrations and features that you can likely enable if you really want to dig deep. J2534 is like OBD-II on steroids.
SAVEUP
Russ
Lake Texoma
2019 Explorer
Where in TX are you located? I don't have my Bronco yet, but it is in production. I have purchased and received the Keypad. I may need some help getting it programmed to the vehicle. I am in the DFW Metro.
mpeugeot
mpeugeot
I am usually in either Corpus Christi or San Angelo, but let me know when you are ready, maybe we can meet up sometime.
TheMostToysWins
Port Jeff NY
2018 Tacoma Off Road,
When I picked up my Bronco there was a keyless entry code on a card included in the paperwork. My truck did not come with the keypad, Can I just buy the keypad and will that code work??
mpeugeot
mpeugeot
I would have to look that one up...
The answer is maybe.
Watch this video. I believe that they may have an answer for you.
TheShark
'23 Bronco 4DR Wildtrak,'24 Maverick Lariat Tremor
I had the dealer add the keypad to my Bronco, they wanted $135 for the keypad and installation. Normally I would do things like this myself, I've messed around with Forscan on my Bronco and Maverick, added NAV to my Maverick but I thought for $135 let them do it.
