How or where to measure for level.
zebrex
Trent
Silver Springs FL
2024 ford lightning
I installed RPG perch collars on my 2025 Bronco Badlands Sasquatch last weekend. My main goal was to increase spring preload to compensate for the tools I carry in the cargo area and the winch mount and bumper I am about to install on the front.
The installation was easy, and I had the Bronco aligned afterward. The change in ride quality was much less noticeable than I expected, which is a good thing.
Here is my problem: I am a little obsessive about this stuff, and visually, the Bronco looks like it may be squatting slightly in the rear. I cannot determine the correct reference points to confirm it.
I initially measured from the ground to the tops of the bumpers:
  • Front bumper: 32 inches
  • Rear bumper: 29 inches
However, if I jack up the rear until the rear bumper measures 32 inches, the Bronco is visibly too high in the back. If I place a level along the tops of the front and rear door handles, it reads about half a bubble high in the rear while jacked up. With the Bronco sitting normally, the door handles are level from front to rear.
I realize the bumpers may be designed at different heights and may not be useful reference points. Where should I measure to accurately determine whether the vehicle is level or squatting in the rear—frame points, pinch welds, wheel openings, or hub center to fender?
I am measuring on level ground and would appreciate hearing what reference points others have used.
Dan-O
Dan
Fountain Hills, AZ
I can’t give you advice on how much rake you’ll want from front to back for compensating additional weight. But as you said , measuring from ground to bumpers won’t be accurate. I think best measuring point for what your looking for is from center of wheel to edge of fender well(wheel opening). I think you may want 1 1/2” higher in back if not more depending on weight you’re adding in cargo area.
gbub
Gary
Costa Mesa CA
2002 Ford Ranger FX4, 1969 Fairlane Cobra, 1970 2800CS BMW, 1961 Austin Healey S
I use the rocker panels or rock sliders at the front and rear to the ground as reference. Those seem to be the most noticeable for leveling.
SHANUT
Craig
Hermann, MO
I measured the body line that runs front to back that’s just above the door handle.
zebrex
Trent
Silver Springs FL
2024 ford lightning
Thank you. If I use that I am a half inch down in the rear. I think my winch and winch mount will fix that
