How much weight on tailgate before reinforcement is needed?
Fonz54
Lou
Monterey, CA
Jeep Commander, Porsche Cayenne, Mercedes C250
Can you share the part number please?
Fonz54
Lou
Monterey, CA
Thanks
ThunderFlash
Doug
Washington
'24 4-dr WT, '22 2-dr WT, '15 Explorer Sport, '02 F250 SD V-10
I just did the Ford Performance Braptor hinge upgrade. I can tell a difference just in the way the door closes. Stock SAS tire with Bison Gear tailgate table (the best). I was getting constant clunk down dirt roads and now they are all gone!!
Curious, did you replace the body side hinge mounts that came with the kit?
Ninjak
Miami
I ran the DV8 Spare tire and accessory guard on my Badlands when I had it held a 37, and I had an ARB compressor and a Broaddict tailgate table. No issues, and I took that RIG off-road all the time.
The BRaptor is the Braptor, so no worries there. I have the same setup there as well, the ARB compressor and the tailgate table.
ThunderFlash
Doug
Washington
I did not. Same part number as a standard SAS. If you are non SAS I’m not sure.
Coolio. I didn't check part numbers, but it seemed to be the same geometry and unpainted, so I skipped it. Then I started to wonder if it was maybe higher strength steel or some slight geometry change that might be a little stiffer. Thanks!
Mikem1025
San Antonio
2023 Bronco
AGS has a setup too. I went that route because I wanted the dual ARB compressor behind the spare. Not sure how much "extra" reinforcement it gives me though.
Q1svt
Sunny & Warm SoCal
2025 Badlands, Sas-sy Manual 2dr, # of fords
… ? Since you have a sas, did you have to trim the ‘carrier’ (edited not support) to get … the support.. around the tire carrier.​
I read mix messages about it and had been awaiting my tire rotation.
tkx
ThunderFlash
Doug
Washington
… ? Since you have a sas, did you have to trim the support to get around the tire carrier.
tkx
If I recall correctly, believe I trimmed the carrier rather than the TG support.
Q1svt
Sunny & Warm SoCal
Yes the carrier. Do you have a sas? Thought the Braptor and sas tire carrier are the same…. Mine is a 25 BL
And don’t need to be cut, but other trim levels do…
DBGBronco
Justin
Kamuela
24 BDSAS
Yes, I trimmed the tire carrier not the new support panel. I just used a hacksaw blade and sanded it smooth. Only took a few minutes and I left the carrier on the tailgate. One less step.
ThunderFlash
Doug
Washington
Yes sir, I installed the FP support on a WT and had to trim the carrier. I just edit my first post above to include the FP instructions. The first one I got was cracked and FP sent me a replacement ASAP, which was great. Overall though, not sure I'd go this route again if I had to buy another.
Q1svt
Sunny & Warm SoCal
Thanks.
Me either. Don’t want to cut the carrier and I picked up an Al sheet to cut bend my own support . Ford’s was so thin I laughed. But it’s cheaper to buy the kit.
ThunderFlash
Doug
Washington
I was expecting something a little more substantial, but it does include more stout hinges that also have light duty accessory attachment points for a dune flag or antenna or lights (6mm or 8mm I think). Probably not stout enough for a fuel can or such, though.
