- Thread starter
- #31
Genius!I would recommend adding enough helium balloons to offset about 1500 lbs.
I could easily tow a 2 horse trailer loaded with horses using a Grand Cherokee Diesel. And didn’t feel it behind me. I was surprised by how capable it was.Unless it's a very short distance, I wouldn't tow 4,500 with a Bronco even if it had the 2.7Liter.
If you don't want the huge truck anymore, maybe look at something like a used Grand Cherokee diesel. I think the towing capacity on that was 7,200 lbs.
Crap, that bad?You should see how the rear squats 2” (3300lb trailer) with a 4dr BL, 2.7 & factory tow and 12% tongue weight.
Ha! Problem is, everyone else on track is silly fast, so gotta keep up. I miss the days when fast cars meant fast drivers, and not just crazy cars with all the Nannie’s keeping everyone safe and “fast”. Slow cars make fast drivers!Switch it put for a 914 or a Caterham.![]()
Your problem will be if you are ever stopped by Smokey.....or break something. If it is found that you towed 4000# Jim Farley will have nothing to do with you. (I image Farley hauls his race car with an Expedition or F350.)Have a base. Once a decent hitch comes out, I will have no problem towing ~ 5000 - 6000. Cross member only hitch is a non starter.
Thats what I said too when I hooked my camper trailer up. A weight distribution setup for my camper isn't an option. The BL suspension is definitely soft.Crap, that bad?
i have no idea lol, i never towed and i sold my wildtrak a month ago,@uae247 @Budewr w just curious, how many KGs is your Badlands / Wildrtrak rated to tow for a braked trailer in UAE / Saudi?
I have zero worries about Smokey. Professional courtesy and all that. Farley can kiss my badge...Your problem will be if you are ever stopped by Smokey.....or break something. If it is found that you towed 4000# Jimsyrte Farley will have nothing to do with you. (I image Farley hauls his race car with an Expedition or F350.)
Tongue weight on a 6000 lb trailer is roughly 750 lbs…..that leaves about 600 lbs for WDH, passengers and cargo to remain within rated weight limits. In addition, the GCWR for a Bronco is about 8800 lb. (Subtract the approx 5,000 lb Bronco base weight leaving 3800 lbs for trailer, passengers, & cargo). The more passengers and cargo in the vehicle, the lower the available towing weight available.Have a base. Once a decent hitch comes out, I will have no problem towing ~ 5000 - 6000. Cross member only hitch is a non starter.
