- Joined
- Feb 21, 2020
- Threads
- 113
- Messages
- 7,316
- Reaction score
- 25,750
- Location
- North Texas
- Vehicle(s)
- SUV
- Your Bronco Model
- Undecided
- Thread starter
- #1
The HOSS (High-Performance Off-Road Stability Suspension) System seems very interesting, time to deep dive. Lets discuss how it works, do I need to upgrade to the Bilstein Position Sensitive Dampers for my Bronco, what does it do for articulation and how does it compare to the competition?
Standard on: Base, Big Bend, Black Diamond andOuter Banks
Standard with Added Bilstein Position Sensitive Dampers on: Badlands, Wildtrak and First Edition
FordBronco_parts_09.jpg: Closeup of the 2021 Bronco independent front suspension featuring two forged aluminum alloy A-arms and available Bilstein long-travel position-sensitive dampers with end-stop control valves.
CHASSIS (from Ford Prelim Spec pdf)
Front: Independent H.O.S.S. (High-Performance, Off-Road, Stability, Suspension) System with twin alloy A-arms
and coil-over springs for optimum off-road stability and control with available H.O.S.S. System with Bilstein® Position Sensitive Dampers.
Rear: Solid five-link rear axle H.O.S.S. (High-Performance, Off-Road, Stability, Suspension) System with coil-over springs for optimum off-road capability and durability with available H.O.S.S. System with Bilstein Position Sensitive Dampers.
FordBronco_parts_08.jpg: Closeup of the 2021 Bronco independent front suspension featuring forged aluminum alloy lower A-arm.The Bronco’s suspension is definitely up to the task of taking on the Wrangler. Like the Ranger on which it is based, the Bronco has an independent front suspension. But unlike the Ranger, it has a five-link, coil-sprung solid rear axle — a Dana 44 Advantek unit. Available upgrades include long-travel, position-sensitive Bilstein off-road shock absorbers with end-stop control valves, Spicer front and rear electronic locking differentials, and a semi-active hydraulic stabilizer bar that the Bronco can electronically disconnect and reconnect during articulation, not just on stable, level terrain in calm conditions. Ford is calling its suspension the HOSS system — for High Performance Off-Road Stability Suspension System. It provides 17% more travel than the best a Wrangler can deliver, with a claimed 10 inches of front articulation and even more in the rear.
https://www.cars.com/articles/2021-...d-4-door-jeep-has-some-homework-to-do-423739/
