Horrible window rattle if opened partially
Acadist
WA
2023 BadSquatch
Hi All,
Is there anything I can do about a very bad window rattle if the windows are partially opened?
It sounds as if the may break under normal driving conditions. I have brought my car in for this and was told there is nothing wrong.
The Drivers door also catches on the top lip as if tis not dropping in time when I open the door at times.
thanks for your help or suggestions.
P.S.
Anyone's hood open alarm for off for no reason?
The advice I was given, wheel with the windows all the way up or all the way down, never in between
Shane78
Shane
St. Louis
2D
DM’d you. Thanks for looking into it
Idk, just relaying my experience. I have 7 year 125k ESP and they wanted to charge me 300 to diagnose. Then came on here and learned about adjusting it myself. Your experience may vary at another dealer I guess. 🤷🏻‍♂️
helifino16
Ron
Mount Sinai, NY (Long Island)
@MikeC51
You'd be surprised at how easy that is to fix.
Get yourself a deep 10mm socket. Open the door and lie under it. There's two rubber patches (about 2"x3") (they're plugs actually) on the bottom of the door. They pull out easily.
Loosen the nut (maybe 1/2 turn) just inside that opening and push it to the outside of the door and retighten. Repeat for the other one and replace the plugs.
The hardest part of this process for me is getting up after I'm done. It made a WORLD of difference. I can ride with the windows cracked or 1/2 way down without the annoying rattle. It still MAY happen on a rough patch of road, but is significantly less than it was.
jdbabb4247
Wernersville, PA
2022 Ford Bronco OBX
Hi All,
P.S.
Summer, winter, I always drive with the windows down around 1/2", and it is extremely annoying, but I've been told there is nothing that can be done at this time so I just live with it.
Badlandsjoe
Joe
Osprey Florida
2023 Badlands 1972 Jeep cj5 renegade 66 gto coupe
As far as the window hitting the top lip have you tried the window reset procedure
Windows needing reset steps:
1) open window and hold button down for 10 seconds
2) close window and hold button down for 10 seconds
repeat 2 more times on same window if needed
  • Like
Reactions: LCW
MikeC51
MikeC51
New Jersey
Colorado ZR2
@MikeC51
I’ll definitely give it a try, thanks
MikeC51
MikeC51
New Jersey
Colorado ZR2
Thanks for the reset steps. I used to have to do this to my Mustang
1st 75th ranger
jeffrey
nj
Hi All,
P.S.
you tube ...easy fix i do drivers window every 3 mths as its used more
Combustion_King
Derek
MA
Yes
Yeah the adjustments don’t fix the issue. Which is why Ford removed that TSB.
They’re still working on a fix for the concern. Current information is Q3 of this year.
It helped mine a lot, i can now drive with the window lowered, and the rattle is pretty much gone unless im hit a really rough section.
PS: i have had the hood alarm go off twice in a year and a half. both times i recently had the hood open, no idea what causes it.
Ducati1098
Yeah it seems to help some and not others.
As far as the hood alarm, the latch probably needs to be replaced. There was an SSM for it, very common
Combustion_King
Derek
MA
Yes
i just click OK and go on my way lol.
