ShaneQ
Shane
Palmyra
2024 Bronco, 2010 Ford Ranger, 1988 Ford Ranger, 2005 Ford Thunderbird
I've wanted to install mudflaps since I bought my two door Black Diamond Bronco, but the only ones that had the coverage and design I wanted were the Gatorbacks, and I couldn't see spending $500 on mudflaps.
I wanted them to be rubber, so that they would be flexible, I didn't want poly or plastic, and I wanted more coverage than most aftermarket options offered. I didn't want to drill into the Bronco, and I've had bad luck with the cheap plastic mounts on aftermarket ones on my Ranger.
So, I decided to make my own. First order of business was to design a simple bracket that was sturdy, and easily mountable. Fire up the plasma cutter!
Ford Bronco Homemade custom mudflaps DIY 1000001783
For the rear, this is what I came up with, it mounts to the rear cab mount with a single nut.
Ford Bronco Homemade custom mudflaps DIY IMG_20260111_162016000
For the mount itself, I didn't want to have external nuts, plus there isn't really room for them on the front, the way I was designing my bracket for them. So I used press in PEM nuts.
Ford Bronco Homemade custom mudflaps DIY 1000001785
Ford Bronco Homemade custom mudflaps DIY 1000001786
Ford Bronco Homemade custom mudflaps DIY 1000001787
All pressed in! Now I can just bolt the flap onto the bracket, and I don't have to worry about losing the nuts.
Ford Bronco Homemade custom mudflaps DIY 1000001799
Ford Bronco Homemade custom mudflaps DIY 1000001796
Bracket in place, before mounting the flap.
Ford Bronco Homemade custom mudflaps DIY IMG_20260111_163105454_HDR
Ford Bronco Homemade custom mudflaps DIY IMG_20260111_163313636
Ford Bronco Homemade custom mudflaps DIY IMG_20260111_163334130
Ford Bronco Homemade custom mudflaps DIY IMG_20260111_164610415_HDR
The rear, all set!
For the front, I wanted a bracket that would mount with the intrusion mount bolts.
Ford Bronco Homemade custom mudflaps DIY IMG_20260112_162355747_HDR
Same idea as the rear, it used press in PEM nuts for the mudflaps.
Ford Bronco Homemade custom mudflaps DIY IMG_20260112_161543697
Ford Bronco Homemade custom mudflaps DIY IMG_20260112_161707594_HDR
Ford Bronco Homemade custom mudflaps DIY IMG_20260112_161655437
My rock sliders were in the way, so I had to trim a hole into the flaps so that they would sit correctly.
Ford Bronco Homemade custom mudflaps DIY IMG_20260112_162347279_HDR
Ford Bronco Homemade custom mudflaps DIY IMG_20260112_162335178_HDR
Front installed
Ford Bronco Homemade custom mudflaps DIY IMG_20260112_171356908
Now I did have to use two #8 screws, and two 1-inch nylon spacers at the top of the flap, and screw the flap into the plastic fender flare. I didn't want to, but the screw threads are hidden in the space between the inside and outside walls of the flare, so no big deal.
Ford Bronco Homemade custom mudflaps DIY IMG_20260112_171423691
Ford Bronco Homemade custom mudflaps DIY IMG_20260112_171506300_HDR
Ford Bronco Homemade custom mudflaps DIY IMG_20260112_171516449_HDR
And the front mudflap, all installed. You can see from the spray on the door that I really needed these!
Ford Bronco Homemade custom mudflaps DIY IMG_20260112_173514931_HDR
Ford Bronco Homemade custom mudflaps DIY IMG_20260112_173501644_HDR
Ford Bronco Homemade custom mudflaps DIY IMG_20260112_173526498_HDR
The beauty of these is I can put longer flaps on if I want, or I could even design poly flaps if rubber isn't desired.
Maybe this will give someone else an idea how to set mudflaps up on their Bronco, or if there's any interest, I could produce the brackets for others, that way you can set the mudflap up to get the coverage you want.
I should note this setup should work with any Bronco that isn't a Sasquatch. Obviously the brackets would need to be longer on a Sasquatch to provide the coverage for the wider wheels.
CitrusBronco
Everglades
Citrus county, FL
Everglades
Great job.
I made my own also with very similar front brackets. I knew I would need heavier steel but used some thin stainless stock I had to start. I upgraded the brackets since this pic.
I went for full coverage but I can trim them down anytime in the future.
Ford Bronco Homemade custom mudflaps DIY IMG_6059
Ford Bronco Homemade custom mudflaps DIY IMG_6063
aermtr
Don
Portland Or
broflaps.etsy.com
'20 GT500 CFTP, 65 Cobra and '23 Badlands 2.3 7MT
Well done. I did the exact same thing back in 2021 when I bought an FE (which wasn’t my final build). It turned into a business. You can tell everyone your flaps are made in America!
Ford Bronco Homemade custom mudflaps DIY IMG_3260
Ford Bronco Homemade custom mudflaps DIY IMG_8458
Ford Bronco Homemade custom mudflaps DIY IMG_3292
DBX2
Tennessee
2025 Stroppe; 2025 Harley RG3; 2025 HD Street Glide; 1997 HD Heritage Sp
Appreciate the ingenuity Shane.
*Recognize your picture aermtr....we got your Broflaps and are 1000% satisfied. Your team is great!
Broadcast Static
Dan
Kentucky
F150 - 2021 XL 4x4 Supercab, 2024 Bronco Badlands Sas 7MT 2door
What do you think you'd charge for a set of Sasquatch brackets?
4dtrkman
Russ
Kingsport TN
F150 / Edge
So you sell these. Are they brackets or the flaps as well do they bolt on a SAS ?
Big Norwegian
Central Wisconsin
F250, F350, F600
Way to go, can't find what you want make it yourself. I do the same thing made my mudflaps out of an old floor mat work great and didn't drill any holes to mount them
ShaneQ
Shane
Palmyra
I understand if you don't want to tell me, but how did you get started listing yours for sale? How did you get the word out?
Props to you as well, I've heard a lot of guys absolutely love your product, and your customer service.
ShaneQ
Shane
Palmyra
I'm not 100 % sure yet, only because I need a Sasquatch to test fit them on, and I'd also like to test fit them on a 4 door, since mines a 2 door, and I'm not sure if the rear body mount lines up the same as my 2 door. But I can definitely keep you posted! And appreciate the interest.
aermtr
Don
Portland Or
broflaps.etsy.com
@ShaneQ, We started with Etsy and eBay and it was early on when Gatorback was pretty much the only option. Since then, we launched our own site (broflaps.com). I originally made my own flaps (like you) from stuff I bought online and then built some jigs for scale and consistency and started advertising. At first it was kind of a joke but I was so shocked at the prices, I figured “why not”. To our surprise it took off and quickly turned into a total disaster. I thought every Bronco model rear bumper was the same as my FE at the time and clearly that was an oversight. So we bought back about half the kits we initially sold. That prompted me to spend several weekends at the Ford dealer laying under Broncos with templates and measuring tapes to get all the combinations right. Since then, we struck a deal with Duraflap and they make our Premium flaps for us in Monroe Wa, our exclusive design. We’ve sold around 2,000 kits so far, and it’s been amazing because even when we screw something up it seems like Bronco owners are always a class act. Anyways, we’re not big like some of the other brands yet, but we only focus on Broncos, and make continuous improvements often from customer feedback. The other benefit is that I can write off all the other stuff we buy for our Bronco on our taxes:).
QUOTE="DBX2, post: 2722027, member: 55334"]
[/QUOTE]
aermtr
Don
Portland Or
broflaps.etsy.com
@4dtrkman, yes we do, full kits with flaps, all hardware, videos and instructions. This bracket is used on the plastic rear bumper models (Base, Wildtrak, OBX and Big Bend). We’re a sponsor on 6G and more details on our site at broflaps.com. Thanks! Don
ShaneQ
Shane
Palmyra
Thank you so much for the information, I really appreciate it!
Area51BS
Ron
Badlands non SAS 4dr 2.3
Nice work
