Highest octane we can run without a tune
Dmorty217
Derek
Venice FL
Camery
What the highest octane level we can run without a tune before the computer starts having issues? Not 93 or 94 octane but 100-105 octane is what I’m specifically asking about.
mpeugeot
Short answer, it will make a ton of power on E30 without any additional tuning. I was shocked how much E30 woke it up.
Example: an Ecoboost Mustang tried 3x to pull me at 80-100 mph and failed hard. No way that would have happened without the E85/93 mix (E30).
Blksn955.o
Greg
Wentzville, MO
17 Ford Escape Ti, 94 Ford Mustang GT, 21 BL
octane rating is the resistance to burn with the higher the rating the harder to burn. You want to run the lowest octane you can without pre ignition to get the most use/ performance generally.
E fuel above the commonly available E10 or less really should be tuned for the specific mix when needed. E85 has a great octane rating but requires IIRC around 30% more fuel.
Leaded is when things go south as they gum up cats and mess up o2 sensors...I know some guys back in the day used to mix turbo blue with 93 octane on boosted setups just for a little bit of safety when 100 unleaded was not available.
In short 91-93 is probably all we need unless you are really pushing things then you are moving into the specialty E85 and 100+unleaded/leaded tuned setups and at that point you are kinda all in unless you have different tunes for different fuel setups.
Dmorty217
Dmorty217
Derek
Venice FL
Camery
I am getting the CRP 53mm stage 3 turbo upgrade done to a second turbo I have sitting in my garage and once someone can crack the ECU and I can get a few tunes to work with the turbo and higher octanes is why I am asking
lapazleo
Indiana
2022 bronco badlands
93 octane is all you need without higher compression pistons or milling heads to raise compression. Unless you start running over 10 to 1 compression more than 93 octane is a waste of money. High compression and turbocharging are a recipe for disaster. Thats why engines with high turbo boost require lower compression. Same holds true for engines with blowers. High octane fuel is for high compression naturally aspirated engines.
mpeugeot
What do you define as high compression/high boost with a turbo? The 2.7 already has 10:1 compression (and some 2.7's ran 10.3:1 compression) while still running about 20 psi of boost.
To be honest, it's much more complicated than saying below 10:1 compression anything above 93 octane is a waste. The fact is that even the difference between direct injection and port injection is a huge game changer for the importance of octane in a turbocharged engine.
The Bronco definitely does benefit from octane above 93 on the stock tune, just run 5-6 gallons of E85 along with 10 gallons of 93 octane sometime if you want some proof.
Silence
SD
2022 Bronco
Generally speaking, 100 octane is more than sufficient for a vehicle without a tune that would ensure no timing retard. There would be no detriment to running other than your wallet.
Turbocharged vehicles benefit greatly with higher octane contrary to the previous message. It depends greatly on the tune and boost target and ramp coupled with the overall compression and timing of the tune. I have ran 105 octane and even leaded mixes (no cats) as well as e85 only tunes in high boost turbo applications for the past 20 years. That said in a completely stock vehicle 93 octane seemingly would be more than capable of hitting all marks on a normal tune.
Dmorty217
Dmorty217
Derek
Venice FL
Camery
I’m currently have the K&N intake,AFe charge pipes, and mishimoto intercooler. Sending off the turbo for the upgrade and patiently waiting on SPD to make a downpipe for the 2.3 or anyone else for that matter. Had a tuner but got rid of it. I’m trying to learn , hence my question.
Silence
SD
2022 Bronco
Of course. Completely understand.
Personally I have exhaust and tune. Was thinking of doing more, but realized for what I intend it is enough but definitely curious to see what happens with performance related items.
TroutTrooper
James
2014 Fiesta ST, 2001 Jeep Wrangler, 1988 Ranger (SVO swap), 1974 Super Beetle
You will receive absolutely no benefit on a stock tune running over 93 pump gas. As a matter of fact, there's an argument to be made that you'd possibly make less power on a higher octane fuel because it is less energy dense, hence its higher resistance to pre-detonation/knock. Do NOT listen to anyone advising you to run higher ethanol content fuels without supporting mods and a tune. Yes, it might technically make a bit more power, but not safely. It takes more ethanol based fuel to maintain a stoichiometric air:fuel ratio than it does with gasoline. "Lean is mean."
mpeugeot
Citation needed. I was running with with an engine monitor and the engine management had no problem adjusting to E30 and made quite a bit more power.
It wasn't lean, it wasn't even close to lean. That said, I am not advising anyone to do anything regarding E85, that's up to anyone who wants to try it. When I was stuck behind enemy lines in California, the 91 Octane pump gas was absolutely horrible, I used to either go to Willow Springs to gas up or add a few gallons Toulene to bump the octane (both better options than E85, if you want to avoid the pitfalls of Ethanol). One legitimate danger of E85 is the need for more frequent oil changes, that is a fact. You don't want to run E85 and not be on top of maintenance, period.
I did notice that my local gas station is selling unleaded 100 octane sunoco 5 gallon buckets. So maybe I will run her down on fuel, load up the Ford performance tune, and put 5 or 10 gallons of real race gas in the Bronco (which has a higher octane than E85).
Now, who here has made more than 300 HP/liter at the wheel on a turbo engine they tuned? 🙋
Silence
SD
2022 Bronco
I can raise my hand on that as well. 3.6L Porsche with over 1200HP.
Not sure why anyone think over 93 would not bring higher performance in this engine on a stock tune. So many factors that would contribute to variables where it would help - load, IAT, fuel quality, etc. E30 is safe on pretty much all modern vehicles as well which your cars ECM can accommodate for the targetted a/f ratios. this isn't a 1975 Pontiac.
robepa
Paul
West Seattle, WA
www.instagram.com
2022 Bronco, 2006 Tacoma, 2020 4Runner
My first job out of collage was working for Dinan as a development engineer, we tested the E39 M5 with different octane fuels up to I think 104 which is the highest before going leaded which would destroy the cats. The E39 M5 made more power with increased octane, we could see it advance the cam and spark timing to take advantage of the fuel. There is a lot of difference between 20 year old BMW NA V8 and a new turbo Ford motor, having said that a turbo motor should be able to take more advantage of higher octane fuel and 20+ years of sensor and computing improvements.
Without a doubt it's not worth the cost of the fuel as the gains are minor, also higher octane fuels tend to make it harder for engines to start with in some conditions as well.
Yeti-X
Todd
Eau Claire WI
2022 Bronco Badlands 4dr
Rotary engines don't count LOL just kidding I couldn't resist
Yeti-X
Todd
Eau Claire WI
Better yet who has made 300 ft/lbs of torque per liter on a turbo engine they tuned.🖐
