I don't think I've ever had that happen with mineYeah but it turns itself on by itself. That's the real issue.
I don't think I've ever had that happen with mineI have the 2.7 auto. I always manually set the parking brake and then manually turn it off. I've never had it do anything on it's own.
I like that the garage door opener will allow me to store up to 3 girlfriends garage doors.I have lux mainly because I'm a top of the line guy. My unbaised opinion is
Thee B&O sounds pretty good but the sub is horrible. A lot of people don't realize sound stage is everything in audio. no door speakers are not going to fix sound quality even with high end speaker replacements. That being said you can save money and install your own audio system that will be better than B&O. If I could remove just this feature I would.
Heated steering wheel is self explanatory. People say it is 'weaker' than other vehicles which I believe to be true, but by NO MEANS does it not work. I use it every day in the winter-spring months. It is great with remote start also. If I could turn it up 10% I would, but it works no problem.
The wireless charger is worthless. I have an apple OEM case and when I got over a mild bump it stops charging. Even when it does 'charge' I'm luckly if I just hold a charge. I'm looking for a plug and play apple mag safe solution. If I could remove this feature I would
Garage door opener is nice, but of course you can just use your clicker instead
ACC is a game changer for rush hour traffic. If you've ever had it in a vehicle you know what I mean. I can no longer live without this feature. I wish it was ACC with stop and go, but even when it disables at 10mph that is better than nothing. Because of ACC I will buy lux 10x over.
Happy to see someone else with this opinion. The B&O in the Bronco is THE MOST underwhelming premium audio I have heard in a vehicle.I have Lux. I am not an audiophile (I'm deaf in one ear, and partially in the other) and the B&O system was disappointing to me. I have replaced all the speakers already... I've only had my Bronco for 5 weeks. if you don't care about the adaptive cruise or heated steering wheel - I say just stick with the high package - consider it a win. put the money towards aftermarket stereo upgrades. Personally I love the adaptive cruise, otherwise, I'd be pretty pissed about spending the money on Lux and getting such a crappy stereo
"depends on how you set it" -- Exactly sir. The fact I had to read up on how to set it... well, was because it was annoying prior to changing settings. AND the collision assist when people are turning to the right, in front of me, gaaah!No, it's never even kicked in for me, and I have been in some spicy driving, depends on how you set it. I have only had collision warning go off less than a 1/2 dozen times in 50k miles. I have it all set to minimum sensitivity.
I am getting ready to write my 50,000 mile review today, and a part of the review is how much I would have hated the Bronco "as delivered". In a world without FORSCAN or this forum, I would have traded it in after the first month."depends on how you set it" -- Exactly sir. The fact I had to read up on how to set it... well, was because it was annoying prior to changing settings. AND the collision assist when people are turning to the right, in front of me, gaaah!
I am not sure the cost of the navigation after. But, the major benefits of having built in nav is two things.Does anyone know the cost of the built in Navigation after the free l 3 year period?
you have the option to delete this feature from the Lux package and save $695, is that correct?
What are the pros and cons to the bult in navigation?
We were off topic. (Talking about my Dad's Exploder, not the Bronco). As far as I know, the stupid E-brake works just fine in the Bronco, but I have only actually used it twice.I don't think I've ever had that happen with mineI have the 2.7 auto. I always manually set the parking brake and then manually turn it off. I've never had it do anything on it's own.
What happens to the BO system over time? To my ears it sounds good and I’m no audio slouch. I’m rocking B&W 702S at home with a Rel subwoofer so audio does matter. Interestingly on the Bronco w/Lux package, I’ve enabled Dolby surround for regular audio playback and I kinda like it.I also heard even the upgraded stereo isn’t that great. I going Lux, because of the ACC, mostly. Otherwise i would be fine with the high package. Even now, I’m having regrets about the lux, because it’s limiting in front bumpers you can get.
Unfortunately, or rather, fortunately, my bronco is built, but stuck in chip hold purgatory. I can’t change it now…
B&O is fine for me and this is coming from a guy that would dump thousands into stereo upgrades 20yrs ago when I was in college. It has good sound and decent thump. I’m more worried about having my tools, Jerry can, and LifeSaver water filter in the back for when the economy collapses than a subwoofer at this point in my life.Agreed - the B&O is not bad , heck, it's even considered good for a stock stereo.
If you want some more sound though, aftermarket for sure.
One thing I found on the Lux package is that you can drop the navigation and that drops $695 from the cost of navigation. That along with dropping towing got me a Quick production date. Ordered 10/11/22 production week 01/09/23.I
Do you mind if I ask how much yours was? I've heard that it's way more costly to upgrade from the regular system vs the B&O, but not sure if there is any truth to that.
Thar should be drops $695 from the cost of Lux packageOne thing I found on the Lux package is that you can drop the navigation and that drops $695 from the cost of navigation. That along with dropping towing got me a Quick production date. Ordered 10/11/22 production week 01/09/23.
Wow that’s a hack! Mine was ordered 10/21 and doesn’t have a vin. I did drop towing, but not navigation. I don’t even care about the navigation, because I use it on my phone no matter what.One thing I found on the Lux package is that you can drop the navigation and that drops $695 from the cost of navigation. That along with dropping towing got me a Quick production date. Ordered 10/11/22 production week 01/09/23.
You might want to check with your dealer to see if that is possible at this point. I've heard the chip restraint is the problem. It worked out for me. Have a VIN # and build date if it holds. Good luck.Wow that’s a hack! Mine was ordered 10/21 and doesn’t have a vin. I did drop towing, but not navigation. I don’t even care about the navigation, because I use it on my phone no matter what.
Yes, you can save $695 off the cost of Lux Package by removing the Navigation. I did on my order.I am not sure the cost of the navigation after. But, the major benefits of having built in nav is two things.
1) it is a gps based system that uses satellites while the connected navigation is cell tower based.
2) when your subscription runs out you lose the advanced nav features (traffic reporting and such), but you still can use turn by turn navigation. The connected navigation just becomes a map with your location.
Or at least that is what I have read.
Thread 'Basic Navigation paywalled - Is this true?' https://www.bronco6g.com/forum/threads/basic-navigation-paywalled-is-this-true.45167/
