High Mount Rough Country Winch
Baldwin69
I continue to see snippets here and there about having to trim some plastic pieces when installing the winch plate I have from rough country. What is this all about?
Any videos or pics are appreciated. Happy new year. David
swami37
Fort Lauderdale Florida
1950 Ford F-1 and 2020 F150 FX4
NeEd to trim the plastic covers under the toe rings
about 2 inches off the inner edge on each one
Copperhorse73
Justin
Mooresville, NC
Another note on trimming, if u buy a winch that is larger than the RC 9500, the retainer caps for the sensors will need more work than the instructions imply. I got a Badlands apex and had to remove about 75% of the cap material. Good news is, the winch holds everything in place just fine, it’s just something to be aware of if you want a larger winch.
BroncoSarge
Jeffrey
Fort Bragg, North Carolina
You have to cut the two plastic pieces for the lower mount to fit back on. Wasn’t hard. I have done it to two Broncos so far.
Ford Bronco High Mount Rough Country Winch F8D7CBD5-7B0A-4991-A0D0-2B7109142118
WheelMe
Patrick
Northern California
2022 Bronco Badlands Sasquatch 2.7L
The Warn EVO 10S is even bigger, and problematic.
I decided to just leave the caps off - for that tough(er)-guy look ;-)
Ford Bronco High Mount Rough Country Winch PXL_20220925_203153463
TallDude
North Seattle
I am also looking at getting this RC mount.
Just would like a winch that doesn’t block the Bronco lettering maybe but that may not really matter in the end. I was thinking of just getting their RC12k winch due to price and good reviews on it.
If I do that and add the Safari Bar it’ll complete the front end, as well as block the Bronco letters, oh well.
WheelMe
Patrick
Northern California
I'm planning on a safari bar as well - it'll probably block letters R and C, but I really don't like the big expanse of a grille as it is currently. The bar will also allow for an alternative location to mount my Hi-Lift.
WheelMe
Patrick
Northern California
Can you expound? The 10S is what I got to go on this mount.
No amount of trimming the end caps that go on the back of the sensors was enough to make use of the caps, as the winch has a larger side profile than others, apparently. My sensors are on there without the caps holding them in. How did you make it work?
Ford Bronco High Mount Rough Country Winch PXL_20220925_201031285
DDraht
greg
Anchorage
F250
So I have the cart before the horse so to speak, already have the RC high winch mount but don't have the Bronco. I was planning on mounting the winch plate as soon as I get the vehcile, which will be before I buy the winch. Based on this I will probably leave off the trim pieces as Wheelme did. I was thinking of going with the 10S as well but now I am wondering if it will fit. I have the factory bull bar on the modular bumper, do you think there is enough clearance that the bull bar will go over the winch? I may have screwd myself if it sits to far back.
Copperhorse73
Justin
Mooresville, NC
I sold my bull bar to a guy who had this setup, it fits just fine
VentureBronco
CA
2022 Base Sasquatch 2-Door
where did you mount the Evo 10S “brain”? I’m looking at this same setup (Rough Country mount+ Warn Evo 10S)…I don’t have sensors for my BaseSquatch so less to deal with I think.
I really like the look without the “brain” on top of the winch… does it work with and without it relocated ?
WheelMe
Patrick
Northern California
The "brain" is under the hood, typically secured with a mount made by BAMF, located in a crevice just fore of the battery (in a V6 model). The relocation requires that an extended-length wire kit be purchased from Warn, as the wires that come with the 10S aren't long enough to snake under the grille and into the engine compartment. As long as the controller is wired to the winch (regardless of wire length), the winch will work.
