Hi all
mObridge
Fraser
Orange County, California
BMW e92 328
Hi guys,
Any Bronco audio questions send them my way!
We will be coming out with some new audio products designed specifically for the Bronco soon!
gwp
Greg
Winchester, Virginia
Harley Davidson FLTRUSE
Hi guys,
We will be coming out with some new product designed specifically for the Bronco soon!
“some new product”. Helpful info, thank you.
Bronkers
Ben
Las Vegas, NV
2022 2dr Bronco
Hi guys,
Is your new product a widget that spits out 4x low level (or line level) *full range* high-quality signal from the factory head with near painless install? That would seem a miracle, but I may have not researched enough.
Oh and if that's your new product, can you hurry up 😉
mObridge
mObridge
Fraser
BMW e92 328
Ok ill spill the beans on one, its a full plug and play amplifier kit for the B&O system that fits in the factory location!
mObridge
mObridge
Fraser
BMW e92 328
What system do you have?
We are working on a kit to do this for the base system but it is a little while away. If you have the B&O system we already have this!
Cat
Cat
Whidbey Island, WA
MB500SL, HD Road King Custom
Show me.
Bronkers
Ben
Las Vegas, NV
2022 2dr Bronco
Dang, base/smaller touchscreen
How long is a little while away? 🤔
mObridge
mObridge
Fraser
BMW e92 328
mObridge
mObridge
Fraser
BMW e92 328
Hopefully in the next 3 months if all goes well! if you'd to be on the waiting list shoot an email me a PM with your email address and i can keep you updated.
eduard4us
Eduard
Lancaster, PA
Ford Bronco
Combustion_King
Derek
MA
Yes
well now. lets see what we got here... :devilish:
Combustion_King
Derek
MA
Yes
So this straight replaces the B&O amp, does it need its own power wires run, or is everything all integrated 100% will this need a FORscan modification.
will the gain options built in, allow for speakers that are not 75w RMS rated? my 4" dashes gonna explode :ROFLMAO:
this is an awesome perk to not having to run all new speaker wires off an amp, super interested in this, and with a sub to match in the factory spot, im sold on this clean install:love:
mObridge
mObridge
Fraser
BMW e92 328
Can’t wait for the kit! It was good chatting with you on the phone this week and getting my questions answered.
Fraser, put me down for one kit when it becomes available
Eduard
Hi Eduard,
You're on the list!
Little sneak peak for you I verified the amp will mount in the factory location
Ford Bronco Hi all 60F0456C-5397-4C7C-869E-17D9DEB318B7
mObridge
mObridge
Fraser
BMW e92 328
Unfortunately you will definitely have to run thicker power wires, we will have a how to video for this shortly. Not actually as big of a job as I thought it would be as there is a spare gromet in the firewall. Our kit will include everything you need shortly!
So if you want to run the factory speakers, our amp has channel limit settings you can setup so you don't overdrive them!
No forscan coding needed, no wires cut. Full plug and play just need to do some wire running.
Combustion_King
Derek
MA
Yes
Thanks for the quick replay, i am not running factory speakers, but im also not running ones that can handle 75rms,, so that good to know that the amp can tone it down, huge plus for me in buying this.
as for the power, its just like a regular amp install i assume then, power, fuse, ground,, and remote is built into the factory harness stuff?
One last question, if i was replacing the sub, would i be running a duel coil bc of the factory wiring, or can i use whatever sub fits and there's a wiring harness to convert the factory connections to single coil
Look forward to completed "kit"
