Help with ForScan and B&O System
mdube72
Matt
NH
Audi SQ5
I don't think you can do anything with Forscan for the B&O system. I went ahead and did the SSV Works pods and swapped out the two dash speakers with DS18 speakers and it made a huge difference. I am happy with it now. Might replace the subwoofer eventually as well but for now I'm good.
@DamnYankee - if your looking to do the subwoofer in the B&O - I recently added the new Gearshade subwoofer box made for the B&O. Very happy with how it turned out - here is a link. Had to trim off the small circle plastic inside the rear trim panel that was designed for the circle subwoofer of the factory sub with a dremel. It’s probably not an issue for those upgrading to a circle sub like the Kicker. The square Kicker L7T8 packs a massive punch with the Kicker Key 500
https://www.bronco6g.com/forum/thre...r-enclosure-2-door-version.82851/post-2218825
YankeeScouser
Ft. Lauderdale, FL
2022 Badlands, 2022 Mercedes CLS63, 1983 Porsche 944, 1986 Porsche 911 Targa
So I just installed the SSV Pods with kicker marine 6.5". I changed the 4th speaker only in forscan to Tweeter / Speaker / Sub (A) and the rears came alive. I belive the 3rd speaker is set to no speaker from the factory as the B&O amp controls them both AND the sub through the 4th speaker code It bumps like now. Wayyyyy more midrange and bass coming from teh 6.5's
