Help Us Develop New Products for Bronco 2-Door Models!
endovein
jeff
delaware
bronco wildtrak
Molle basket for rear window areas and aftermarket hard top for two door, billet running boards since Archetype seems to have folded and screwed everyone
DUSTYcazOREGON
Craig
2022 Bronco Black Diamond & 2025 Yukon Denali. 2023 Mercedes Adventure Wagon.
A platform or pull out tray that sits in the rear cargo area....of the height that with the rear seats folded forward.....it creates a level surface...level to the seats folded down. This could be a pull out tray or an easily removed open ended platform so to speak. Strong enough to put about 100 lbs. upon it. A platform that is held in place just by it's own weight and the weight of what it carries would be nice. Easy to remove and would be easy to design and make. Similar to your basket but straight up on the ends and no lip around the top (so things like dog crates, no matter what size would fit.
ADDED: Looking at your cargo basket; flip it upside down so the lip faces downward, make different support legs that are 90 degrees downward not slanted outward, maybe one support brace in the center if needed. NOT bolted in....one that just sits in the cargo area of a height that creates a level surface with the 2 seats down. Your current basket may be a little too wide and may need to be shortened. Leave a little play on both sides for those that have side wall molly panels already. This "Lower Support-Open Ended Lower Shelf" would allow storage underneath it, create a level surface for sleeping, dog crates, larger items, easily removed...still allowing access to in floor OEM panels. For me personally, it will solve issues with dog crates as I need a larger level surface. Thank you for considering. Photo of my side molly...hoping it could remain
@BA OffRoad
You need to make this for the 2 door and 4 door. Thanks!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
JonD
Jon
Maryland
Suburu Outback
I have 2022 wt 2dr and looking for storage solutions while still being able to store the 2 PC tops. Back seats are always down 95 percent of the time. Need a decent fire extinguisher attachment also. Some better lighting in back would also help.
TacosTuesday
Carlsbad, CA
'23 Badlands 2dr 2.7L
100% want to buy a rear tonneau cover and a rear cargo shelf that folds down & is built to be quickly detachable/removable. and it doesnt block the 12v power & light in the rear.
also want something to fill in the B pillar area to give it a finished look with the top off.
Surge
2025 2dr Bronco Badlands Marsh Gray
I am interested in a rear cargo platform for my 2 door Black Diamond. However, what I'm really interested in is a sliding tailgate. My ICECO VL45 fits nicely behind the rear seats but takes up almost all the space. A cargo basket above it would be awesome, but only if I can slide the fridge out to open it.
Basically what I'm looking for is a fridge slide that slides on the short axis. Something like this but uses the Bronco cargo tie down mount points.
MORryde SP56-115 Slide-Out Freezer Tray - 31.42" x 19.7", Front Pull
+1 on this. Fridge slide using tie downs, cargo basket above.
EvilJim1971
Jemison Al, 35085, USA
www.instagram.com
2023 Bronco Heritage Edition
You guys are bringing out a slide out tray and drawer system for the 4 door. Many of us have removed our rear seats.
A similar setup for the 2 door without rear seats or an adapter plate to use the 4 door product in our 2 doors.
Badlands Traveler
Mojave Desert
Ford F150 XTL 4x4 2019. Bronco Badlands Sasquatch
Please make a fire extinguisher bracket to fit on the rollbar in the back Bronco. Thanks!
WallyBalls
Tennessee
2024 Ford Bronco Big Bend 2 Door
Yep, pretty much the common request. Tonneau cover from the front seats to the gate. We would love for it to be somewhat waterproof, or at least resistant. Running topless from March through November down in the RVA.
I still long for one...
