Help locate airbag module
Eduard
High point, nc
Hi,
I need help to locate airbag module on my 2023 bronco outer banks.
Ducati1098
Under the center console
Eduard
High point, nc
Do you know on which side of the shifter ? Towards the back where arm rest is or towards the front under dashboard? I checked under center console around shifter and didn’t see any where.
Thanks
Squirrel13
Brad
KY
Another clue is to follow yellow wire loom. Usually, SRS stuff is in yellow loom, yellow wires with colored tracers and plugs.
Ducati1098
Thanks
It's behind the shifter. Under the actual storage area. The whole console has to be removed.
Eduard
High point, nc
Thank you, found it .
Steeroba
Robert
Roseville, Ca
2023 4D Bad Sas Lux & 67 Old School
Does anyone know if Ford relocated this module for 2025 year to make room for new rear AC vents?
