Help finding part # for missing bolt on roof rack?
jh3113
Jake
Phoenix
Subaru Outback
Did you ever end up getting a replacement bolt? Ended up striping the f&$% out of mine because i was being dumb. Probably going to habe to rep-tap the hole, but the fastener is hosed.
thesedays
Boise, Idaho
2022 Ford Bronco
thanks again for our help. I'm going to attach a couple of pictures showing the bolt. hoping this helps if you are using the same type. again this bolt is located in the rear bracket to secure the clamp to the roof.
I missed place this same bolt, just curious if you were able find this or substitute?
Thanks.
Hector
Anyone have the exact thread pitch and length of this bolt handy?
Mg2424
Houston
Someone on another thread purchased this Volvo one and said it worked. I just ordered two that will arrive in about a week to see. OEM Volvo Part # 8698547
CiNeverGlades
FOX
Cincinnati, OH, 45223
2023 FORD BRONCO BB 7MT 4DR 2.3L CBNFBR GRY
Mg2424
Houston
I see it's been almost 1.4 years ago since you were looking for this part. How you've found one by now.
https://usparts.volvocars.com/p/Volvo__/Roof-Rack-Bolt-SCREW/42820143/8698547.html
Just received and yes. I ordered two from some store named euro online as they were cheaper. Triangle special head and just installed fit perfectly. It’s a pain to install. Best to take off the one bolt cover so you can see the cylinder it has to screw in to with a little screwdriver to make sure it goes in straight as it spins.
Mg2424
Houston
FCP euro is where I ordered from when I googled the part number
Mg2424
Houston
Little more clarification
Ford Bronco Help finding part # for missing bolt on roof rack? IMG_6304
Nomadik
East
2021 Bronco FE
Apparently you can get It on Amazon too. The number in the title isn't the Volvo part number which is confusing. In the description it says that the Volvo part number is 8698547 which is the part needed.
Volvo Genuine Load Bar Replacement Mounting Bolt - 31463574
projectrally
Adam
South Portland, ME
2019 MX-5 RF / Factory Five 818 / 2018 CX-5 GT
How about bolt G from the OP’s attached diagram? I am missing one of those…
