Hellacious mirror whistle -- simple FIX = RTV silicone!
Blue32
Josh
2021 bronco
Hey all! So here's a super simple fix to the obnoxious whistle coming from the driver's side mirror-- which admittedly took me some time to pinpoint. I'm sure there's a handful of other fixes out there, but this worked for me.
Run some RTV along the seam. I ran some painter's tape along the outside of the mirror just to keep a clean line, but otherwise it's just that simple. Whistle gone.
Hope this helps.
Cheers! 🍻
Ford Bronco Hellacious mirror whistle -- simple FIX = RTV silicone! IMG_0357
Ford Bronco Hellacious mirror whistle -- simple FIX = RTV silicone! IMG_0358
Copperhorse73
Justin
Mooresville, NC
I happen to have some RTV in the garage, will be trying this tonight. Did the rtv want to stick to the tape when u removed it, or did u run a blade across the edge before removing tape?
Bschurr
NY
Genius & simple fix @Blue32 Am I the only lucky guy who doesn’t have whistling mirrors?
ogo
High Point, NC
2022 JLU Rubicon
I think the whistle was dependent upon trim level, not sure though. The trims with the cameras or zone lighting in the mirrors may not have the whistle.
I think there was also some whistling on some vehicles from the front of the hood
Blue32
Blue32
Josh
2021 bronco
Nope, no sticking. I just ran a small bead and then smoothed it over with my finger, pressing it into the crack. I pulled the tape immediately- last pic was fresh RTV before it cured.
Blue32
Blue32
Josh
2021 bronco
I think you're correct. I have a BB without cameras and lighting, and it's loud! ...or was, rather. 💪
KnoxGnater
Nat
Knoxville, TN
1934 Ford Roadster Pickup, Bronco Badlands
Mine whistles above 80 MPH, especially with a cross wind. Not sure if it’s mirrors or the ditch lights. Badsquatch with Lux.
OP did it go away if you folded the mirrors in at speed?
Blue32
Blue32
Josh
2021 bronco
Yes, It did go away when I folded the mirror in and when I placed my hand along the outside, which ultimately led me to the root of the problem. My whistling started around 30/40mph. The good news is this fix completely eliminated the mirror whistle.
Hornet
Ford Explorer
Hope this helps.
Cheers! 🍻
New BB owner. The wind noise drivers side mirror still an issue. The seam on the edge as pictured in other posts is the issue. You can feel the edge with your hand. Filling the crack or covering with electrical tape will fix it. I filled the crack with black flex seal. Can't see it unless you're looking for it.
kyle
Austin, TX
Subaru Crosstrek
My big bend 2dr whistles... I'll try it out. The whistle though sounds more behind or above my head on the MIC top. If your post fixes it I'll send you some Mcdonalds.
Blue32
Blue32
Josh
2021 bronco
I thought the same thing. I started with some adhesive foam in the front seams on the MIC, and it didn't help. The roof rack rails also make some noise if you have those, but that also wasn't the culprit. Give it a try and report back. My whistle went from 100 to 0 with this fix. Good luck! 🎶🎶🎶
Twistedbrilliance
Ryan
Ontario, Canada
2021 Badlands, 2007 Jeep JKU
So far, I have not had any complaints about whistling mirrors or wind noise with my soft-top. I have a 2021 Badlands 4-door with steel modular bumper. If there is a strong side wind coming off the farm fields, then it can get a little noisy, but that's not unique to the Bronco.
