Hard top - rear electronics
DUSTYcazOREGON
Craig
2022 Bronco Black Diamond & 2025 Yukon Denali. 2023 Mercedes Adventure Wagon.
i dont know an exact delivery date, but I’m able to order now with delivery late summer.
Without a reservation and ordering this late....delivery will be in 2022....probably later in 2022.
Montana Bronco
Montana
Chevy
The whole wiper/defrost on the back window is overrated IMHO. My Subaru’s quit working 10 years ago and I did not miss it. This is in Montana, lots of snow.
They make these things, it’s called a brush. Every gas station has them for $1.99. You need to use them anyway, even if you have the back wiper. Example =
Ford Bronco Hard top - rear electronics 7458E0A9-87FB-4900-917D-450BE79AB842
da_jokker
Jeep Wrangler JKUR
Was reading thread and looked in the wiring diagram to see if it differentiated between soft and hard tops which it doesn't.....
It has been established that you don't get the plugs located just inside the left cargo area.
But maybe what has not been established is what do those plugs control. I think we've all figured it was for the defroster AND the windshield wiper but maybe it's just for part of it?
Or did Ford include the wiring in the door regardless, but then removed the wiring in the body... Makes no flipping sense.
flip
Phil
IN
www.ruxerparts.com
Fords
Unless the diagram is wrong or doesn't reflect the different top options, the wires should be in the harness somewhere. I guess it's possible they are there and stop at one of the connectors prior to where they terminate in the back but that isn't a big issue since the connectors will be the same regardless. Easy to figure out what the pigtail is to get the right male and female terminal pins so not concerned about hardware as much as if the steering control module has the ability to enable the rear wiper/washer function.
