Harbor Freight badlands jack mount
Mysilvstang
Inverness, Fl
2024 Bronco Raptor, 2024 Ranger Raptor
Saw a video about this box so i ordered one, it fits behind the rear seat in a 2 door. It has room for other equipment such as shackles and snatch blocks etc. The jack fits perfect in it. Plus it has wheels on one end to help move it to and from the vehicle
Ford Bronco Harbor Freight badlands jack mount IMG_1259
Ford Bronco Harbor Freight badlands jack mount IMG_1260
Knownman
Matt
Southern California
2021 Bronco Badlands Sasquatch.
Agreed with this. In addition since I’m lifted I also bought the safe jack extensions and pads. You can buy the whole kit from safe jack or save a few bucks buying the bottle jack from Amazon.
I'm not sure I agree with you or any of the bottle jack comments. I have the Safe Jack, which is terribly expensive for what it is, and now I own the Badlands. I bought it after trying to use the Safejack on my rig on the pavement in front of my house. Even with the extensions that thing is a PITA at best. It has so little throw, lifting range, that its basically useless unless you carry around several wood wedge blocks to get it perfectly set. Just think about how you might get positioned on the trail when you need a jack. Where you can actually lift on the Bronco and what to what the dirt, gravel, sand, grass or whatever is underneath.
Like it or to the ease of use of the Badlands is just superior. Its footprint is way more stable and It'll get that rig lifted in almost any situation regardless of the terrain. But it is big and heavy.
LuisF.Recio
Luis
Houston, Texas
2022 Ford Bronco
My plan for a jack to test in the future will be the TPS Off Road Inflatable Jack (4 Ton).
Easy to transport but most important, there's 2 ways to inflate: first, connecting the 20-feet hose to an exhaust pipe, you can easily inflate the jack with car exhaust; Second, you can use air compressor to inflate it
Ford Bronco Harbor Freight badlands jack mount 7155092_xl
Ford Bronco Harbor Freight badlands jack mount 7155092_xl2
Felix808
SRV CA
Yeah, I can just imagine trying to use that hemorrhoid in a rocky section of trail 😏
LuisF.Recio
Luis
Houston, Texas
2022 Ford Bronco
Won't be to much different with the badlands rolling jack. You will need to be on flat surface.
The only one that will work in the rock area is the "chin breaker" farm jack.
The off-road jack comes with a mat (my guess will be heavy duty). If that's not the case, a can get or make one for a few bucks. 😏
Ford Bronco Harbor Freight badlands jack mount fdfd
Imaginary Friend
Southern MN
A passel of Fords and a Jeep JL Rubi
Around here I've seen more than one of the hardcore off-roaders mounting hi-lift jacks in place of rear bumpers on fabbed mounts.
derichio02
Bo
Southern California
Bronco Badlands, Maverick, Tesla M3, F250 Tremor
Do you have a link to this box? Is it the 108qt one?
Ninjak
Miami
Do not have a jack, never been in the position to need it off-road, but If I was going to get one, the Badland Jack is what I would end up with. If your stock, is at stock height, maybe the scissor jack or a bottle jack works. If you're modded, sitting on 37's, those jacks may not be any help at all, never mind the stability part.
Call me lazy, but a floor jack is what I would want to use. These jacks are like insurance. You don't need it UNTIL you need it. Hell even in a mall lot.
Felix808
SRV CA
Well at least the give you extra patches for when it gets punctured :sneaky:
Bikeric
Tulsa
2022 Badlands LUX on 37's
I already have the rear seats removed from my 2-door. This thing is big, bulky, heavy, and rattles like an SOB everyday. I'm not sure I want to keep it in my rig anymore.
Ford Bronco {thread} {filename}
swooshdave
Portland, Oregon
Mustang
Should be dead easy to add some rubber strips to reduce the noise.
https://a.co/d/3RcdaDx
swooshdave
Portland, Oregon
Mustang
Oh, I've already done all that and more. I keep a blanket over the top of it as well now. It is just an endless rattle source. 🤷‍♂️
I don't see anything in your pictures.
Here's where I would start.
Ford Bronco Harbor Freight badlands jack mount 6zXHviu
Bikeric
Tulsa
That picture was from initial installation, Day 1. Everything you have an arrow pointing at is now covered.
The rattles can be attributed to the jack itself. The axles? The plastic wheels? The sloppy bushings? The adapter stand? Anything and everything about the jack just rattles. Hopefully you can understand. 🤷‍♂️
