- Phil
- Jul 21, 2020
- 45
- 4,837
- 16,030
- IN
- Website
- www.ruxerparts.com
- Fords
- Badlands
Tailgate Alignment
Inspection
NOTE: Removal steps in this procedure may contain installation details.
Adjustment
All alignments
Tailgate left and right, up and down alignment
Tailgate in and out alignment - on latch side
All alignments
Inspection
- Check tailgate-to-body dimensions.
All alignments
- Remove the nuts and the spares wheel.
Torque: 41 lb.ft (55 Nm)
- Open the tailgate about 5 to 10 degrees.
- Note down the movement in tailgate due to spare wheel removal. Noted movement due to tire weight should be accounted during final alignment.
- Remove the RH rear lamp assembly.
Refer to: Rear Lamp Assembly (417-01 Exterior Lighting, Removal and Installation).
- Open the tailgate.
- Remove the bump stop.
- Remove the bolts and the striker.
- Loosen the bolts.
Loosen:
: 2 turn(s)
- Loosen the bolts.
- Loosen the bolts.
Loosen:
: 2 turn(s)
- Adjust the tailgate as required.
- Tighten the bolts.
Torque: 30 lb.ft (40 Nm)
Torque: 17 lb.ft (23 Nm)
- Install the striker and the bolts.
Torque: 18 lb.ft (25 Nm)
- Install the bump stop.
Torque: 22 lb.ft (30 Nm)
- Install the RH rear lamp assembly.
- Remove the fasteners and the tailgate hinge cover.
- Mark the location of the tailgate hinge to aid in installation.
- Loosen the bolts.
Loosen:
: 2 turn(s)
- Close the tailgate.
- Loosen the bolts.
Loosen:
: 2 turn(s)
- Loosen the bolts.
- Install the spare wheel and the nuts.
- Inspect the body-to-tailgate door dimensions.
- Install the positioned aside and removed components.
