Grille Marker Lights Installed
EXO Bronco
Upland, CA
Explorer ST, Audi S4, Raptor (Previously)
Installed some “Raptor Style” marker lights in the grille, love how it turned out. Looks factory for sure.
Took a little creative fabrication with the help of a 3D printer for the backing plates to mount them with, but it wasn’t hard.
Used these ones: YEASOU Led Front Grille Light for 2004-2019 Ford F150 F250 F350 Raptor and 2013-2018 Dodge Ram 1500,3Pcs Smoked Lens Amber Light https://www.amazon.com/dp/B0991RMT1...t_i_EA24VPZ89FNN9JVR7J3D?_encoding=UTF8&psc=1
Ford Bronco Grille Marker Lights Installed 8AA23917-1D1F-4024-AC75-F85246515944
Ford Bronco Grille Marker Lights Installed 04AE39CE-B7AC-48EC-95CB-887A2B22A12C
Ford Bronco Grille Marker Lights Installed 34D4CC5C-4431-4E09-B7CE-A89EAB18AD79
Ford Bronco Grille Marker Lights Installed B58D5EF4-42DB-4419-BE09-2B774C97D1EF
Ford Bronco Grille Marker Lights Installed D7C5E82C-0B64-4DA7-B1FE-77DE22D6D6D6
Amcole1984
Amber
2021 2 door Bronco Big Bend
Love those! I wonder if they would fit as nicely in my Big Bend grill? Did yoy wire them to come on with your lights or to a switch?
Garemlin
Delaware
Prerunner lights are getting a little played out. But I don't hate them on the Bronco. Looks good. I personally would have gone with white.
EXO Bronco
EXO Bronco
Upland, CA
For now they’re running off an up fitter switch… will probably change it to just tap into ACC power once I have a need to use that switch (if ever).
MOON
2011 Jeep Grand Cherokee
daddycreswell
Josh
Tenneessee
2013 Raptor, 1973 Bronco
I tend to agree with you on other models ie Toyota, Dodge etc. But Ford I think they look great, bias I reckon since they are on my Raptor. I haven't decide if I will install on my NB, but I can almost bet ya they will be on the Braptor when it comes out.
Patotas
Andrew
Chandler,az
Did you have to wire these up to an AUX switch?
EXO Bronco
EXO Bronco
Upland, CA
You can wire to anything you want. I used Aux switch 6, but I may move to an always on ACC circuit.
Mustang Mike
Toronto Ontario
Mustang GT
Marker lights on my Black Diamond!
I ordered 3 sets off Amazon and this was the set that most closely matched the factory amber parking lights!
Ford Bronco Grille Marker Lights Installed 766C4E19-A683-47F3-B5A7-CB86A242E7EB
Marauder
Josh
St Louis
Do you recall which ones?
Mustang Mike
Toronto Ontario
Mustang GT
Marauder
Josh
St Louis
Zac
Zac
Kentucky
2022 Ford Bronco 4-door
How did you mount/attach the marker lights to the grille? I've been trying to come up with ideas, but haven't figured out a good solution yet. All the DIY tutorials I've seen here have been for the BL/WT grille, which has much smaller openings.
