Got super glue on the dash šŸ˜­ Looking for advice
Inrustwetrust_
Inrustwetrust_
Alex
Peoples Republic of Massachusetts
2021 Bronco 2dr
If i mess up bad enough I guess thereā€™s thisā€¦ or maybe vinyl wrap like suggested
Ford Bronco Got super glue on the dash šŸ˜­ Looking for advice 138C3FCC-A31C-4827-9957-E628F7B5CD66
Inrustwetrust_
Inrustwetrust_
Alex
2021 Bronco 2dr
Do you think you can scrape it off with plastic razorblades? I've used them successfully in the past to remove similar types of contamination.
it feels like itā€™s mostly stuck in the dash texture
da_jokker
Jeep Wrangler JKUR
Wow, all these years and I guess I misunderstood how super glue worked. I thought the whole point was that it attacked the plastic and basically melted it together. Not that it just stuck to both sides with a thin layer.
If it didn't actually melt the plastic, that I think that you'll be okay if you can find some concoction that will loosen and have it peel up so there is hope if that is the case.
Maine Explorer
Ben
Maine
22 bronco
Anything you're planning on trying should be tried on a less visible area first.
I see a lot of good ideas in this thread I'd just test them somewhere less visible before trying them, just my 2 cents.
Hope it's an easy fix
Inrustwetrust_
Inrustwetrust_
Alex
2021 Bronco 2dr
Tonightā€™s progress. Getting better but still showing a little. Used an eraser and a cheapo Amazon steamer
Ford Bronco Got super glue on the dash šŸ˜­ Looking for advice CE96CEAA-D62B-42E1-B023-45FD41173729
da_jokker
Jeep Wrangler JKUR
Super glue works by melting the plastic.. it's not an adhesive glue. Unless it didn't attack that plastic, you are not going to be able to buff it out.
Inrustwetrust_
Inrustwetrust_
Alex
2021 Bronco 2dr
Resurrected on Easter! While this is on the front pageā€¦
what was the outcome op?
A slightly faded super glue stainā€¦ Iā€™ve learned to live with it and have some worse blemishes after a year of ownership haha
