Good reverse light setup?
5.0Maverick
Todd
Nj
1970 maverick.
Any good reverse light setups that are understated but effective?
Rubicon
Tod
2 door Wrangler Rubicon
MESO Customs HitchPod with Baja Design S1
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
We have 2 options for you
First up, is the Baja Designs Spare Tire Reverse Kit
https://www.4x4truckleds.com/baja-designs-reverse-kit-for-2021-ford-bronco/
This kit includes a bracket that mounts to your spare tire. It keeps a pair of S1/S2/Squadron lights up high away from the ground (good if you off-road a lot and are worried about something hanging from the bumper).
The bracket included with the kit bolts onto the 3 factory lug nuts that hold your spare tire on (they provide extensions in the kit for the bracket). A harness is included that let's you run the power line up to your factory upfitter/aux switches (or if you don't have those, you can opt for their toggle switch harness). One tip is to just route the wire to your rear passenger panel, where Ford has already ran a pass-through wire for you (this is just a wire that is pre-run and goes into the passenger front kick panel, where you can then connect it to ANOTHER wire Ford ran for you that goes into the engine bay).
You can also add on an optional license plate mount to also keep that license plate up high (pictured here)
Next up is a kit that we put together ourselves. Our Baja Designs Reverse Light Kit
https://www.4x4truckleds.com/2021-ford-bronco-reverse-light-kit-w-baja-designs/
This kit includes mounting brackets from KR Off-Road (the manufacturing side of our business). It allows you to mount the lights below your bumper in a variety of heights. You can mount them hanging way down low OR you can have them tucked right under the bumper (which DOES put them out of the way of hitting anything, as you'd hit your muffler before you hit your reverse lights).
The main different with our kit is that we also provide you one of our CrystaLux harnesses (CrystaLux is another in-house brand focusing on LED replacement bulbs and harnesses). This harness taps into your factory reverse circuit so that your lights come on automatically when you go into reverse. On top of that, we also allow you to also control the reverse lights from a factory upfitter switch. So now you can turn those reverse lights on from a switch (one tip is to get some amber covers, throw them on the reverse lights and now you've got chase lights for the trail!).
This is the kit we run on our demo truck since it keeps the lights tucked up under the bumper and less visible.
These kits are all in stock and ship within 24 hours (orders placed before 1pm EST usually ship the same day from our warehouse)
sklnbnzaz
Graham
Phoenix
Bronco, Ranger
I like the idea of these brackets for under the bumper, also that they're stainless and powder coated. How long are they? Just want to climb under there with a tape measure and try to visualize it. Seems like a pretty simple and functional solution.
4x4TruckLEDs.com
Adam
Lindenhurst, NY
The kit gives you a few mounting options. So you can have them tucked right under the bumper or hanging a few inches below based on how you bolt the mounts up and on the brackets
This is in mm. The left hole is the hole that you'd possibly use on the bumper (although you could use another one)
Ford Bronco Good reverse light setup? 1647642715927
Bronco21fan
Angelo
NewJersey
I was looking at the Baja desighns xl linkable lights for the roof does the wire to the light really stay on the outside of the Windshield I think that looks tacky as hell any way to run the wire without it being on the outside or am I missing something
sklnbnzaz
Graham
Phoenix
Bronco, Ranger
Thanks a ton!
The_Axeman
Sean
Montréal, Québec, Canada
2021 Ford Bronco 4dr Badlands 7MT
Maybe this could help or be a budget solution for you:
