GOAT Modes - How do they work? Can you adjust them?
Gamecock
  • Thread starter
  • Banned
  • #1
I'm trying to wrap my head around the GOAT modes and how they will actually work. I was looking at the chart below, which I know is based on assumptions and other vehicles, but it says a couple of other things that are confusing like:
1) "keep in mind these are only assists, and can be manually adjusted if you so choose".
Does that mean I can modify one of the modes to mimic Sport mode on a Badlands? According to the chart, there is no way to run in 2H on a Badlands with an open exhaust and tight steering. That would be hard to get past...but maybe I am missing how these systems work. Any insight?
*Chart was made up by another user, so I deleted it*
BroncoActual
2018 Ford F-150 Raptor
If it's anything like the Raptors, it'll be presets that you scroll to that alter settings for the columns listed in the bottom table. From there, you can then manually change a few things
e.g. if I went to Mud/Sand mode on my Raptor, it sets me to 4H, locks rear diff, sets Comfort steering, turns off traction control, and alters my shift points. I can alter from this default setting like toggle the rear diff lock off, traction control level, and steering feel
Razorback
Dallas
Lincoln MKX
It's my understanding that on the BLs, select baja and then manually switch to 2H would be equivalent to sport.
Gamecock
Gamecock
  • Thread starter
  • Banned
  • #4
Oh, that makes sense...as long as it lets you manually adjust to 2h and stay in Baja.
Silver-Bolt
Eureka, MT
Negative. Baja and Sport are nothing alike. You will not like Baja mode on the street. Sport mode on the street is great.
Razorback
Dallas
Lincoln MKX
Why would they make it different than the Raptor? The technology is the same...
Silver-Bolt
Eureka, MT
In my Raptor Baja and Sport do not perform the same. Going to Baja and switching to 2H is not that same as Sport.
Shotsy
Massachusetts
'22 Ford Bronco, '18 BMW m240i, '04 Honda Element
SevenT
1970 U15 Sport Edition; 2021 AMB 4 Door Badlands
Razorback
Dallas
Lincoln MKX
Looks like sport doesn't spool the turbos like baja. Baja is more linear power that gets in the power range much quicker and keeps the RPMs up when you need the power immediately.
Used2jeep
Massachuvian
2007 Crown Vic P71
QUESTION: "What GOOAT mode would Bon Jovi use?"
"SLIPPERY" (When Wet)
Natai
Sean
Sacramento
Nissan Sentra, Mercedes GLC
Baja alters traction control to allow for more slippage on sand. You do NOT want this on pavement. In general, you don't want to use any of the off-road modes on pavement for this reason. Even mentioned in a video about the modes.
As far as we know right now, there is no way to easily replicate Sport mode on the Badlands. Only chance is if someone figures out a way to modify the settings (or unlock Sport if it's just hidden) through so sort of software trickery.
The Bronze
Kelly
1986 Suzuki Samurai, 1967 Ford Bronco, 1993 Turbo Notchback, 2006 Sierra K1500, 2013 Sierra K1500, 2014 Sienna Mini-Van
There will be some modifications you will be able to make to the PCM portion of the modes, one the PCM is hacked. Things like throttle response are tables available to customize the feel through aftermarket tuning platforms at owners warranty peril. I am curious if we will have access to other goat mode tables to trailer to our likings. Patiently waiting....
