GOAT mode for towing
dgorsett
colorado
F250, Mustang, Explorer
I don't tow a lot, but I use Sport. The more aggressive shift points, both up and down, fit towing nicely, especially in hilly, curvy Colorado. I have noticed any difference in steering or braking
gbub
Gary
Costa Mesa CA
2002 Ford Ranger FX4, 1969 Fairlane Cobra, 1970 2800CS BMW, 1961 Austin Healey S
Baja mode for towing seems like a bad idea. You would need to take it out of 4WD and unlock the rear differential if you do use Baja. I think Sport mode is better for towing but putting it in 2WD would certainly be recommended.
Leafy
Jon
Nh
2024 2 Door Badlands, Manual
Do any broncos ship with the tow mode? If you try and code it in with forscan it just makes the dash reboot whenever you select the mode.
Booker’s Bronco
Pappy
Wilsonville KY
2024 Bronco
my Bronco: 2024 Big Bend.
2.3L automatic with 4.27 gears and 33” tires
i do not have tow mode available.
i just did a 900 mile trip @ 65-70 mph with a empty 6 x 10’ trailer.
I tried “Normal “ and got horrible mpg. 14 maybe. I suspect the Rpms were too low for the turbo to make good power.
On my return 900 miles i used “Sport” mode and got closer to 16.5 mpg.
Noticeably better power. Of course the overdrive gears are disabled in “Sport” mode which in my opinion is better for towing.
I tried this over the weekend towing a 2000 lb trailer. First in normal and got 15.8 mpg, towed just fine. On return trip, used Sport and got 13.5 mpg but it certainly had more power and more responsive. Was hoping for the mpg increase like you had.
dgorsett
colorado
Uphill? Downhill? Wind? I like Sport for towing just for the responsiveness and control on hills if nothing else.
