Goat mode cap/cover
BroncoU812
Zachary
Washington, PA
2021 2dr Black Diamond
So I was on a short trail today. It was mostly very light mud, ruts and creek crossings and I had the dog with me. He likes riding in the bronco more than I do. He gets so pumped that he starts jumping from the front to the back, over the center console, sticking his head out the windows. Today it finally happened. When jumping back into the back I hit a rut and he stepped on the 4hi button. Not a big deal at all as I was barely going 15mph but it did get me wondering if this could happened going down the highway.
Does anyone know if there is some kind of cover or cap that goes around the goat mode dial? If not it might be a cool project for the 3d printer guys on here.
Ford Bronco Goat mode cap/cover IMG_4104_b65b96ab-4122-4cbd-a0aa-c7720d895e43_480x480
BroncoU812
BroncoU812
Zachary
Washington, PA
Looks like a laundry detergent bottle cap might fit. I'm sure there's something that fits
Spray paint can cap
A bet a paint can cap might work until I get something more polished 👍
BroncoU812
BroncoU812
Zachary
Washington, PA
Trade for a stick shift? That puts the Goat Dial on the other side of the shifter where it is more protected.
Something to keep in mind for the next order
shieldsy
'79 Bronco XLT
Laundry bottle top?
3D printed in plastic?
It really wouldn’t be a b6g mod unless it was executed in brushed billet aluminum, color coded to your trim level and included your VIN # engraved on the part.
Lifeliberty
Moonbeam👀
Columbus, OH
I've been thinking about this. First, the cylinder hugs the dial so you can still rotate it, with a flip-top cap you open for 4x4... like you were going to fire missiles
And it can have a decal
"in case of emergency"
Ground_zero298
Scs michigan
Lifeliberty
Moonbeam👀
Columbus, OH
Ground_zero298
Scs michigan
That was what i thought of. If it were taller, with a perch on the GOAT(I'm officially calling it the goat from here on out) sides extended up another 1/4 or 1/2 in. with a Flip top plexi cover
Exactly what I was thinking. This already has the dimensions. Just need to make it taller and add something to the top. Not permanent either, you can pull it off and toss it in the glove box when no dogs aboard.
Lifeliberty
Moonbeam👀
Columbus, OH
I can see a use for it(if someone needs a reason to build it, and also locker button covers)
Thread 'PSA: Transmission drivetrain damage can happen from pushing the wrong button' https://www.bronco6g.com/forum/thre...n-happen-from-pushing-the-wrong-button.48512/
Ground_zero298
Scs michigan
Ground_zero298
Scs michigan
At this stage a 3D print cap cover would be good when out and about. Just pull it off to change drive modes. I’ll grab the micrometer if someone needs measurement on the aluminum one.
1/2” taller and a clear piece of plastic would fit right inside it.
