GMRS Radio
DefNotBuddyLee
Austin
Mustang / Jeep / F150
Question, what frequencies were we using at the Safari? I was all ready to buy a set of radios and I'm learning different groups use different radios and frequencies. It seems that one group I went out with, and maybe the Bronco Safari used preset channels in the 400Mhz-520Mhz range and SoCal Broncos (Big Bear Bash) uses the lower racing frequencies down 136Mhz-174Mhz. If I'm correct????
If true I should get a dual channel radio like this:
BAOFENG BF-F8HP (UV-5R 3rd Gen) 8-Watt Dual Band Two-Way Radio (136-174MHz VHF & 400-520MHz UHF) Includes Full Kit with Large Battery.
Or
BaoFeng UV-82HP (Blue) High Power Dual Band Radio: 136-174mhz (VHF) 400-520mhz (UHF) Amateur (Ham) Portable Two-Way
The first one has a bigger battery and the other is blue (maybe newer) and has three different settings for power level, 1, 5, or 7/8 watts.
BaoFeng is definitely the budget route, but I love them. We can carry about 3 or 4 with no worries about handing out if anyone in our run forgot one. Just keep in mind that because of FCC licensing issue, the UV-5R (and many models) can only receive on GMRS and no longer transmit. However, if you accidentally did the factory reset (just google) then bam...you got yourself a radio that can transmit/receive.
Arrowbear Rider
Marcus
Laguna Woods, Ca
Bronco, Triumph Thunderbird Commander 1700
I was originally looking at the Midlands, but then I found out that different groups use different bands. Nobody has really confirmed, but I'm thinking the Bronco Safari used "common channels" that are in the 400 Mhz range???
And, the local Bronco club uses the lower 130-170Mhz, (146.535 to 151.995 per their spread sheet) channels used by raced teams, so I guess there's less weekend traffic where they wheel. So, I wasn't seeing dual band (the lower freq) on the Midlands and started to follow links from different forums, which led me to the BaoFeng.
I'd rather have something like the Midland, I just need to known what product works for both clubs. I also want to be able to talk with whatever brand radios others are using and it seemed the programmable could do that, can the Midlands handhelds without the keypad do that?
It's confusing because the more I learn, i.e. dual bands v tri-bands, locked out, slapped by FCC, but can unlock, the more I don't know. I'm sorry if I'm being dense here, but it seems some say I use this and it works great, that but didn't answer if "this" works for both clubs and all brands.
ksdon
kansas
You are not being dense. It is confusing.
In the general public there is CB, Murs, FRS radio bands that do not require a license.
Then there is Amateur or Ham, GMRS, Maritime (boat) and various business bands that do require a license. If you dig some more you can find others. And then there is Public Safety...government but that is not for us.
This is a chart to help you see what is where by frequency: https://transition.fcc.gov/Bureaus/OPP/working_papers/oppwp38chart.pdf
It is also confusing, but kind of helps see where a a radio frequency might belong.
UtahBrandon
Brandon
www.puravidaoffroad.com
a number of classics and my 4dr Badlands
We used GMRS channels on Bronco Safari. my Midland MX275 was great and I loaned out a handheld to another Bronco that didn't have a radio.
Gnomad
Harbor Springs
Land Rover LR3 HSE
Hey Arrowbear Rider, this post isn't a dig at you, it's meant to be strictly informative!
any frequency from the 146.535 to 148.00 is in the 2 meter amateur radio band and is illegal for those without a ham license. Above that is business band where the folks who legally use these frequencies pay for the privilege and users run the risk of interference.
OTOH, most low power radios don't have the range to interfere with anything beyond a limited range and it's not like the FCC realistically enforces anything that doesn't interfere with public safety. I've known plenty of people who use the lowly Baofeng on ham, GMRS, FRS etc and nobody has ever been tagged for it. I'm certainly not advocating the use of frequencies you don't have privileges to use. You'll have to decide your own aversion to risk, eh?
I have both ham and GMRS licenses. And that GMRS license was a merry chase through more than one gummint website that took a good hour and a half to navigate. Worth it for trail communications but when you venture in to the FCC website buckle up buttercup!
Arrowbear Rider
Marcus
Laguna Woods, Ca
Thanks for the info, above is much of what I'm seeing after a couple of weeks of researching. My community has several clubs, and a ham radio club just happens to be one of them and they had an "all clubs" promotional event where I was able to talk with them. The first guy wasn't much help with new info, but just confirmed a lot of what I already knew, but the second guy was more helpful and I can join if I want to/have the time to. I have no problem getting a license and I've seen links on the other forum on how to, some have found ways that seem a little easier than others have experienced.
It's going to be one of nicer radios, one that is dual band or better, maybe a mobile one too in a couple of months. I'm leaning on just one nice, current generation radio to get familiar with the usage, programming, license and etc. I may get a mobile unit later and then use the handheld for a spotter or to loan.
dcaero
Bronco OBX SAS
@Bmadda I ordered the identical connector to @UtahBrandon and the cable did not work. Messed with it a bit and the connector that went into the main radio was not working. Bought a new connector, cut the bad one off and replaced it and it works like a charm.
PSA: If you buy one of these extension cables, maybe buy a few to make sure you get a good one and then return.
Ford Bronco GMRS Radio IMG20230526184143
Losy
Long Beach, CA
Gen 1 Raptor, GL63, S7
Helpful thread... How loud and clear is the Midland MX275 speaker from the handheld? I listen to louder music when off roading and tend to have trouble hearing from the handhelds I have used.
telenerd
Laramie
Subaru
I got a 3 pack of radios from Walmart. Some offbrand. I used them for back country skiing and my friend was way down a steep ridge and could hear him very clearly at the top and was pleasantly surprised. When I use the radios for small group rides this summer they will be more than adequate. Just my 2 cents.
darinhouston
Darin
U.S.
Bronco, Jeep Wrangler, Bronco Sport, Pallisade
Technically, the Baofang radios aren't legal to use on FRS/GMRS (other than the specific GMRS-only models they have) and you aren't supposed to use custom antennas on those channels. But, people do. I'm licensed for GMRS - but that doesn't give you the right to use those radios - without the license, you aren't even "supposed" to be using GMRS and are limited to FRS channels (but people do). Just information.
If you still want to do it, or are just curious, here are the frequencies for the FRS and GMRS channels so you can communicate with those other GMRS/FRS folks...
GMRS and FRS Frequencies
The table below lists all the FRS and GMRS channels. FRS only radios have channels 1-14. Radios with both GMRS and FRS have channels 1-22.
Channel #GMRS
Channel Name
FrequencyUsageMax Power
GMRS / FRS
1Interstitial 5625462.5625 MHzGMRS / FRS5 Watts / FRS 2W
2Interstitial 5875462.5875 MHzGMRS / FRS5 Watts / FRS 2W
3Interstitial 6125462.6125 MHzGMRS / FRS5 Watts / FRS 2W
4Interstitial 6375462.6375 MHzGMRS / FRS5 Watts / FRS 2W
5Interstitial 6625462.6625 MHzGMRS / FRS5 Watts / FRS 2W
6Interstitial 6875462.6875 MHzGMRS / FRS5 Watts / FRS 2W
7Interstitial 7125462.7125 MHzGMRS / FRS5 Watts / FRS 2W
8Interstitial 7125467.5625 MHzGMRS / FRS1/2 Watts / FRS 1/2W
9Interstitial 7125467.5875 MHzGMRS / FRS1/2 Watts / FRS 1/2W
10Interstitial 7125467.6125 MHzGMRS / FRS1/2 Watts / FRS 1/2W
11Interstitial 7125467.6375 MHzGMRS / FRS1/2 Watts / FRS 1/2W
12Interstitial 7125467.6625 MHzGMRS / FRS1/2 Watts / FRS 1/2W
13Interstitial 7125467.6875 MHzGMRS / FRS1/2 Watts / FRS 1/2W
14Interstitial 7125467.7125 MHzGMRS / FRS1/2 Watts / FRS 1/2W
15Lower 550462.5500 MHzGMRS Only50 Watts
16Lower 575462.5750 MHzGMRS Only50 Watts
17Lower 600462.6000 MHzGMRS Only50 Watts
18Lower 625462.6250 MHzGMRS Only50 Watts
19Lower 650462.6500 MHzGMRS Only50 Watts
20Lower 675462.6750 MHzGMRS Only50 Watts
21Lower 700462.7000 MHzGMRS Only50 Watts
22Lower 725462.7250 MHzGMRS Only50 Watts
15RPUpper 550467.5500 MHzGMRS Repeater Transmit50 Watts
16RPUpper 575467.5750 MHzGMRS Repeater Transmit50 Watts
17RPUpper 600467.6000 MHzGMRS Repeater Transmit50 Watts
18RPUpper 625467.6250 MHzGMRS Repeater Transmit50 Watts
19RPUpper 650467.6500 MHzGMRS Repeater Transmit50 Watts
20RPUpper 675467.6750 MHzGMRS Repeater Transmit50 Watts
21RPUpper 700467.7000 MHzGMRS Repeater Transmit50 Watts
22RPUpper 725467.7250 MHzGMRS Repeater Transmit50 Watts
