GMRS radio mount location?
wilmerfjohnson
Wilmer
Moore Twp, PA
2018 Fusion, 2009 Mariner, 2000 Taurus, 1996 Bronco, 1994 F-150, 1988 F-150, 1984 Bronco II, 1978 F-350, 1974 VW Thing
Hi! Looking for pics and tips from thise who've "been there done that" and installed a gmrs radio - I'm looking at the Midland 40 watt. I can't find a good place to mount it without ripping out the glove box door or center console lid.
Bonnie6G
Kyle
Denver
Badlands LuxSquatch
I ended up going with the Wouxun 50w due to it having a removable faceplate. I plan to mount the full radio body in the console and mount the faceplate on the BYOD rail on the dash.
https://www.buytwowayradios.com/wouxun-kg-1000g.html
mountainbronco
Bonnie, i got same radio. How are you going to get the faceplate cable on top of dash?
I am thinking of whole radio in center console storage (has power) and only need to bring in antenna. That lid has a cable indent for the mic cable, so invisible to prying eyes.
mtap
Mervin
Cape Coral, FL
Toyota Tundra, Hummer H3, Harley Sportster
I went with MXT275…planning to mount the base unit towards the rear by the tailgate and running a mic extension to center console. So far i have the antenna done and ran the antenna wire already. Working on the rest on Thursday.
Ford Bronco GMRS radio mount location? 1CAC36A2-648F-45DE-9414-65F6CA39FAC6
Ford Bronco GMRS radio mount location? 926186E0-EE54-488D-BD46-88370AECA761
Ford Bronco GMRS radio mount location? CCB3469A-592E-4B37-94EF-ADC089B6C178
Bonnie6G
Kyle
Denver
Badlands LuxSquatch
Yeah, that’s my plan B. I have to remove part of the dash to install the Auto Start Eliminator cable, so I figured I’d find somewhere to route it then. Not sure if I’ll be successful, but Plan A is to route the cable under the entire center console and up through the dash so it comes out near the windshield. If it’s too much of a pain in the ass, then I’ll just put the whole thing in the console.
Felix808
SRV CA
Curious as to how the TX/RX is with that location.
mountainbronco
I think it will be fine, we either have MIC or softtop, both cant handle a antenna, but both are not signal blockers either. I am lip-mounting my antenna to the hood, which is just as good or bad, I guess.
ICUGAZN
Kevin
Woodbridge, Virginia
2019 Raptor
NVCowboy
William
Henderson, NV
Can someone bend up a mount that attaches to the screw holes where the passenger console grab handle is? I don’t know if it would seriously affect the passenger legroom in this position or not, or if there’s enough room. Just brainstorming.
kodiakisland
Arkansas
Going with the MXT275 as well. Haven’t decided on exact mounting yet, but may mount under seat or behind console.
ICUGAZN
Kevin
2019 Raptor
here are a couple of examples
GMRS Installed in 2021 Bronco Base | Bronco6G - 2021+ Ford Bronco & Bronco Raptor Forum, News, Blog & Owners Community
Mobile Ham Radio (FTM-400XDR) Install - DIY How-To / Writeup / Pics | Bronco6G - 2021+ Ford Bronco & Bronco Raptor Forum, News, Blog & Owners Community
Lazerus
Sean
Las Vegas, NV
Wrangler JL. Land Rover Discovery Sport
I have the MXT275 in my Wrangler mounted in the glove box. It takes up almost no room, and with the controls on the handset, don't need access to the base.
I use the 6db antenna, side mounted on the driver's side and it works great. Even with only 15 watts, I can easily hit local (line of sightish) repeaters out to 40 or 50 miles.
Ford Bronco GMRS radio mount location? PSX_20210223_175917
7722 Bronco
Kentucky
2020 Explorer ST/ 2019 F350 CC DRW 4x4
Did the 6db whip require tuning or was it good to go out of the box? I also have the MXT275 and the ghost antenna with the lip mount for the hood. Got both antennas to see which works the best.
Lazerus
Sean
Las Vegas, NV
It is supposed to be tuned right out of the box. Mine was. I have an SWR of 1.03 to 1.07 through the entire band, so I know I'm tossing a good, clear signal.
That being said, from the reviews I've seen, QC let's about 5-10% through that aren't quite in tune out of the box.
You'll hear lot's of talk about needing a ground plane as well. I've found this to not really be affected by a lack of one. I've tested it from 35 miles in both the 'best' and 'worst' orientation and the listener couldn't tell a difference in signal strength or quality. That gives you more flexibility in mounting locations.
7722 Bronco
Kentucky
Thank you.
Was planning on the 6db going on the driver's side hood edge similar to ICUGAZN location. Balance out the look with the radio antenna on passenger side. If it gets to hitting the A pillar while wheeling, I'll switch out to the ghost in the same location.
Ford Bronco GMRS radio mount location? FE7B2A72-0560-439F-90C2-E623AD519B83
Ford Bronco GMRS radio mount location? C3F2B00F-6888-4BD7-A3BC-511848D5C8F4
