getting high beam flashes when using low beams?
Dezperado
2023 Bronco
Is this common on Bronco, or do I need to get my headlights aimed?
Almost every time I drive at night I get high beam flashed by an on-coming driver. Seemingly trying to tell me my high-beams are on. They never are. I do have my high-beams on auto, but this happens even when driving down busy streets, when the high beams never come on.
2023 Outer Banks, no additional lift.
Ninjak
Miami
2021 GT500 2021 Bronco Badlands 68 GTA
If you have the led lights, they are bright. If you hit a bump or something they do flash like you have high beams on.
ksdon
kansas
Get a proper headlight adjustment and then you will know that yours are set as they should be.
Both you and others drivers will benefit if your's are not set correctly.
We go to a place that has an electronic headlight aiming machine. It cost us $45.
Rydfree
Benny
Alabama
I have a 1" frt level and readjusted my lights afterward and I have never been flashed . Well except that one time at WalMart but I wasn't in my Bronco :)
@BadBlueBronco
Kc
Los angeles
Lol I get this all the time but on Friday night someone in front of me really wasn’t having it and was “waving” at me out the window. I proceeded to flash my high beams to let them know it’s not that and I can’t do anything about it right now.
Headsong
I do find it hilarious when I get the occasional Flash because I don't think the lights are even close to being bright but other people apparently do from time to time LOL
Lcubed
l
UsA
VW golf r, 2023 ManBadSquatch
any mods or major weight gains on the back end of the vehicle?
it's not unheard of for the lights to be not properly adjusted straight from the factory
HeliPilot
Kenny
CT
2022 2.7L SAS
I was getting flashed in my new F-150 Raptor with Low Beams on. I pulled it into my garage and adjusted them. They were aimed a good 3" too high.
cbrenthus
Western PA
'22 BadSquatch, '02 T/A
I think the problem is that the auto highbeams turn off too quickly, and a lot of other drivers don’t see them turn off. So they just assume your highbeams are still on because they never saw them dim. Heck, I was driving my departments F350 one night and wasn’t even bothering with the highbeams because its halogens weren’t really any better on high. And I got flashed even though the low beams put out the light equivalent of three match sticks. After that I started using the high beams only so oncoming drivers could see me switch them off ;)
Sometimes it’s someone trying to alert you to something ahead - like deer or a cop.
Sometimes, it's just people. I notice if I run my fog lights (OEM lights, nothing crazy) that I get flashed a lot more than not - but most of the time it's deer or someone over on the side of the road.
Capskorner
Frank
Illinois
2019 Jeep Wrangler Unlimited
I have a Jeep (no shaming! :)). But have a Bronco on order - waiting. My Jeep has LED lights and I used to get flashed a lot since they sit higher, like the bronco. A simple Phillips screwdriver adjustment down just a little bit, and the flashes pretty much all went away. So I am a believer in these taller vehicles to just aim down a bit and it will fix the issue. Plus everyone seems so sensitive to headlights now!!! Like everything else.
TrailDust
Adam
Nebraska
23 Bronco, 23 Bronco Sport, 97 F-150, 07 Cummins
Probably just an old guy like me with crappy night vision and driving a low ass '97 Subaru Legacy commute car. Seems like all the new SUV's and pickups with LED's are on high beam, I used to flash occasionally until I realized it was me, lol.
helifino16
Ron
Mount Sinai, NY (Long Island)
Some will say that it's because the Bronco sits higher than your average Corolla. When I get flashed, I just turn on my off-road lights as if to say "You wanna see bright?"
Ford Bronco getting high beam flashes when using low beams? Blue Lights On
Capskorner
Frank
Illinois
hahah…it’s so hard to tell these days.. the Ford pickups seem the worse. I just grin and bare it and look away a bit.. What happened? I used to love night driving…you get older and wear glasses and now it’s all just a big glare! :)
Capskorner
Frank
Illinois
Hahaha….awesome!
